Greddy Ti C - Is this what I think it is?
So I while was installing my new downpipe I was looking at my catback and remembered there is a flange on the pipe that looks like a o2 sensor connection that has a bolt/plug that came with the catback. So what is this for? Is it a o2 sensor connection?
The TI-C is a cat back, what down pipe/test pipe you got? I believe my TI-C has the same bung its your rear O2, but the other questions still remain as they may also have bungs. if so get them as close as possible.
My wideband is right before the test pipe and I had a o2 bung put in the test pipe for the 2nd 02.
I guess what I am asking is did I need to have the o2 boug for the 2nd o2 put in the test pipe or should I have just put it in that bung that came on the catback?
you will prbably need to leave it in and pull the sensor out of the steream to trick th eecu. otherwise you will have to use a sim to pretend there is one there. on the IX it comes out at a strange agle if you add extensions to pull it out of the stream, but it can be done, as thats what i did with this exhaust.
