heat sheild removed
Old Dec 28, 2007 | 06:47 PM
ballallday89's Avatar
heat sheild removed
I removed the heat sheild cover on the manifold and im running soo much cooler. I usually run about 80 degrees C now im running 68 degrees C. Is it bad to run without it?
Old Dec 28, 2007 | 08:37 PM
krazirob's Avatar
no not really. it just releases the hot air into the engine bay more than usual. take your gains though and run with it
Old Dec 28, 2007 | 08:53 PM
So your saying run with it?
Old Dec 28, 2007 | 09:18 PM
awdwannabe's Avatar
Uhhhh.. yeah I'd say so
Old Dec 28, 2007 | 10:08 PM
lockadam2112's Avatar
running cooler meaning coolant temp?
Old Dec 28, 2007 | 10:14 PM
PWevo's Avatar
Why would you remove it, then ask if it's bad? Temp drop can't hurt though.
Old Dec 28, 2007 | 10:37 PM
djslik408's Avatar
Yeah let us know in a few days how it runs!!
Old Dec 28, 2007 | 10:46 PM
h.funk's Avatar
I have had mine off for a year now and have had no problems at all
Old Dec 28, 2007 | 10:49 PM
MitsuJDM's Avatar
80C for coolant is pretty cool to begin with, that is if you're talking about coolant temp.
Old Dec 28, 2007 | 10:53 PM
whoang40's Avatar
the heatshield is also there to cover up the manifold from rain. Otherwise your header will get more rust buildup without it, plus you don't want to burn yourself. Another thing is is you're accelerating from a dead stop, you'd think more hot air is going to get sucked in by your open intake.
Old Dec 28, 2007 | 11:10 PM
h.funk's Avatar
well mine has less rust build up on it after taking it off. Plus you still will burn yourself on the heatshield
Old Dec 29, 2007 | 08:47 AM
Ya, either way i see it is its going to burn on or off. And why would i touch it ha. Raining season is over now for about 6 months. And isnt running cooler better for my car. I live is south florida and it doesnt get cool down here anyways.
Old Dec 30, 2007 | 09:26 PM
evovin's Avatar
My engine got cooler when I took off my under tray! Usually at runing temp I can't hold my mbc to adjust it,can't touch my upper ic pipe. After I removed my undertray I can touch it and its not hot anymore!
