Post Up your Light-weight Evo!
Old Feb 7, 2008 | 06:46 PM
  #46
11secEVO7's Avatar
Originally Posted by U2SLO
Started with an RS ,05.
Greddy Ti exhaust
Tilton clutch super light and flywheel
Ti strut bar
Buschur mustache bar
Buschur front support bar
lightweight brake rotors
lightweight volk RE-30 wheels 17'
Carbon fiber Driveshaft
Mini battery
Carbon Fiber doors F/R
Carbon fiber trunk
NRG lightweight seats
removed complete A/C system
Removed complete carpet
removed rear seat
removed evap system
removed front and rear crash beams
removed rear seatbelts
removed misc brackets under dash
removed misc brackets in engine bay
removed complete ACD system pump/lines/computer transfercase replaced with shepard racing transfercase.
replaced all bushings to poly F/R
apexi coilover suspension
replaced brake hoses and pads
Buschur race block/=no balance shafts inside
replaced hood with carbonfiber one is 1.4 pounds heaver than stock.
That's all I can think of for weight savings right now
Car is 2620 lbs right now.
Probably the lightest street driven evo period.
damn..so far I only got 2..
would love to get my car down to about 2750lbs..
next for me is cf driveshaft, doors and brake kit
Old Feb 7, 2008 | 07:07 PM
  #47
dsmfan95's Avatar
Greddy Ti exhaust
Ti strut bar
Mini battery
Carbon fiber trunk
removed rear seat
removed evap system
Thanks for the list! Gives me something to go by.
Old Feb 7, 2008 | 07:09 PM
  #48
EVOlutionary's Avatar
Getting lighter - just ordered this -
http://www.aspecproducts.com/images.asp?theid=16163
Comes with a warrany against cracking and saves almost 10 pounds off the stock exhaust mani! I should be in the mid 2700's in AX trim by the middle of the season . . .
EVOlutionary
Old Feb 8, 2008 | 03:16 AM
  #49
U2SLO's Avatar
EVOlutionary
Nice piece that will save some weight Ti header wow!
Old Feb 8, 2008 | 03:20 AM
  #50
U2SLO's Avatar
That's easily 130 off the car right there.Door's,carbon shaft,brakes.
Old Feb 8, 2008 | 03:33 AM
  #51
U2SLO's Avatar
Forgot the
AMS mini Radiator
mini carbon Ralli mirrors on doors.
Old Feb 10, 2008 | 09:01 AM
  #52
m3charles's Avatar
I see the sound deadening on floor in front is it anywhere else because on the RS I don't see it anywhere but under the foot pedal's and passenger front??
on my 06 MR;
2 panels on the rear floorpan, l and r
2 panels on the rear wheel arches, l and r
1 panel under the rear seat, very big
1 panel on rear driveline tunnel
2 panels on front driveline tunnel, top and sides
if it's not on the RS that's really cool.
Old Feb 10, 2008 | 11:31 AM
  #53
U2SLO's Avatar
Originally Posted by m3charles
on my 06 MR;
No I don't see any more other than the one's under the foot pedal's and front passenger floor.They are small.Anyone else with an 05' RS can chime in I just don't see any more??????My carpet is removed from the car.
Old Feb 10, 2008 | 06:55 PM
  #54
ribbie78's Avatar
what's your estimated gains with weight savings to equivalent hp gains? somewhere i heard every 100lbs off a car is about the same as gaining 10hp in regards to acceleration.?. anyone have a basic formula for something like that?
i do appreciate lightness...i've grown up around 1100lb classic minis and weight is not their friend.
Old Feb 10, 2008 | 10:01 PM
  #55
ImJoey's Avatar
Wow that header is expensive.Save 5 pounds for $1300+ you must make more money than you can spend.Thats highway robbery where Im from.That amount is just under what I spent in total parts/tune for a 70whp/70wtq gain over base run. Youre a beast At least you get to boast about being 1 of the lucky 399 people to own one.
Old Feb 10, 2008 | 10:04 PM
  #56
ImJoey's Avatar
I remember hearing that every 100lbs should shave off about .1 in the 1/4. Unofficial
Old Feb 11, 2008 | 06:05 AM
  #57
Yes, I am a beast .
True, for a $$/# comparison there are probably other things I could do to lose weight. Heck, I could lose 70# just off my own fat a$$. It is not about the power increase either, as I doubt it will show significant increases over the ported stock mani I have now. A little part of it is just for the "bling" factor. Titanium header, titanium downpipe, titanium cat-delet, titanium cat-back . . .
Also, for the class I race in there are not that many things that are allowed to be changed. I'm at the point now that every pound I take off the car is getting more and more expensive. . . .
BTW, it saves ~ 10 # from the stock manifold. . .
EVOlutionary
Old Feb 25, 2008 | 12:01 AM
  #58
nico's Avatar
Hi Guys
I hope nobody scare when read the weigth of my two evos .
I think mine race evos are the lightest ever build in the world:
The first is based on the evo VIII chassis and the weight is 934 Kg (2057 Lbs)
The second is based on evo VI chassis and the weight is 868 Kg (1911 Lbs)
For get this target a lot of work was done on the chassis , a very large cutting of metal sheet, for have a very stiff frame I used the roll cage reinforced with more tubes in the strategic points.
All the body kit is made in carbon fiber , the following list of parts totally weight. 15 Kg ( 33 Lbs):
front and rear fenders, front and rear doors, front and rear bumpers, bonnet, trunck and hood.
All the brakes ( front and rear, are with carbon fiber rotors and pads, front are 328mm with monobloc brembo 8 pot caliper ( coming from Indy car brake set); rear are 280mm with monobloc brembo 6 pot caliper ( coming from F 1 car brake set)
I'm sorry for my poor english.
Old Feb 25, 2008 | 04:12 AM
  #59
Robevo RS's Avatar
picture... we need that picture!
Old Feb 25, 2008 | 06:34 AM
  #60
nico's Avatar
Thank you Robevo for your help you are served for now with this pictures:
