Boost tapering more than normal?
Old Jan 3, 2008 | 10:05 PM
Mag00n's Avatar
Hi all,
Just purchased an '03 evo with 33k miles no mods besides a blitz turbotimer/boost gauge
The cars feels great low to mid range but quickly tapers to about 1bar, only about 14.5psi(the gauge reads hkpa/bar) This seems low to me. If i shift WOT from 3rd to 4th the boost just holds at 14.5 in 4th never reaching 19. If i roll on in 3rd or 4th itll hit 19 then VERY quickly drop to 1bar.
I searched the archives and it seems 16 is the norm. Should i be concerned about this?
thanks for any help
Old Jan 3, 2008 | 10:08 PM
subydudesti's Avatar
Check for any small boost leaks. but you shouldn't be too concerned, just get a mbc, filter,tbe,fp and a tune and dont worry about it.
Old Jan 3, 2008 | 11:15 PM
Warrtalon's Avatar
It's called boost taper. The reason why you see less when shifting at WOT is because we hit peak boost at lower rpms (3400-3800), and then it tapers constantly from there until you let off. So, if you think rationally, when you rap through the gears (like drag racing), you're never below 5000-5500rpm, which is almost 2000rpm worth of boost taper.
Old Jan 4, 2008 | 02:03 AM
krazirob's Avatar
a MBC controlled my taper just a tad. but we all get taper in the high revs...........
Old Jan 4, 2008 | 08:06 AM
Mag00n's Avatar
Yea Im aware its called boost taper thats why i named the thread boost tapering off
Anyways i just thought 14psi was kinda low it seems the norm for evo8's is to taper to 16's....I guess i wont worry about it too much, it spools up real quick. Thanks for the replies.
Old Jan 4, 2008 | 08:07 AM
Warrtalon's Avatar
Your gauge is just off.
dierr
11
Jul 3, 2014 09:18 PM
BRN-EVO
Aug 28, 2009 04:26 PM
accident
Jul 3, 2007 03:57 PM
jmoudry
Oct 10, 2006 01:47 PM
pog0
37
Jul 14, 2006 10:19 AM
