First log question about gm 3 bar
Old Oct 7, 2006 | 03:25 PM
jmoudry's Avatar
Hey all
Just got my ecu+ installed with the GM 3bar. I did a quick 3rd gear pull but only got to about 6k. Anyway the output from my MAP was hopping between 19.3 and 17.7. Kinda like a saw tooth wave. I this normal? My boost gauge was around 1.5 bar.
Thanks
Old Oct 8, 2006 | 02:32 PM
MalibuJack's Avatar
Well, it depends on the boost source your tapping off.. If its a source shared by an electronic boost controller then its possible..
If you can "feel" it when it does that, then check your plugs it may be misfiring..
Old Oct 10, 2006 | 01:47 PM
sterdyevo's Avatar
Originally Posted by jmoudry
Hey all
Thanks
check your plugs and then make some changes
go luck
jameswwt
Sep 30, 2015 09:35 AM
GGP Wolf
Dec 12, 2007 02:43 PM
joosdawg
Jun 17, 2007 12:13 PM
maikonkun
18
Apr 10, 2006 10:11 PM
BSREVOLUTION
10
Feb 16, 2005 05:56 AM
