gas problem
Old Jan 6, 2008 | 09:38 AM
mirebih's Avatar
gas problem
Let's play another guessing game
When I bought the car I was able to do around 200 miles per tank, mostly streets... few weeks back engine light came on and I went to AutoParts to scan the code, and it said there was a problem with Cat (somethine like Cat Converter Trashold).. 2 days latter, light goes off by itself... But now i notice that I cant get to 160 miles on full tank.. I drive the same like before, but my miles per galons are lot lower. What could cause it, could it be the cat.. I'm getting TBE from BR in few months, I dont want to change the cat now... do you guys think it's cat or could it be something else...
Old Jan 6, 2008 | 09:48 AM
CBRicahrd's Avatar
with out actually seeing the car and being able to diagnos the problem, i would geuss that you cat is bad, and it may have taken a 02 with it.
Old Jan 6, 2008 | 08:45 PM
KenMasters's Avatar
Winter blend fuel has adverse affects on milage, that might be a place to start. Check your gas station to see if they participate in winter blended fuels/
Old Jan 8, 2008 | 04:14 PM
mirebih's Avatar
daaaamn.. i ddint know that.. woooow. crazy. Thanx for info
I Think i'm being to damn cheap now.. I should go to Mitsubishi and get the OEM cat.. and than when I get a 3"TBE from BR, I will get it with delete pipe.. When i'm ready to go on emissions testing, I will stick a cat on..
but I just wanted suggestions from you guys on what else could the problem be
Old Jan 8, 2008 | 04:25 PM
bmguser's Avatar
the code might be stored in the ecu and may be dumping more fuel as cheap security... maybe cat is having a problem? stock cat?
Old Jan 9, 2008 | 04:45 PM
mirebih's Avatar
yeah, it's stock... I was thinking of restarting the ECU, but wasnt sure if it will help, but since u mentioned it, i will try it.
Old Jan 9, 2008 | 05:12 PM
KcEvil8's Avatar
the cat is like a filter for the exhaust. it wont effect ur gas mileage. it only there for emission purpose.
Old Jan 9, 2008 | 05:52 PM
BBS's Avatar
BBS
You probably got a cat ineffeciency code. It probably wasnt even a registered code and more a pending one. I wouldn't be too worried about the cel. Reset the ecu and run it through its cycles. Your mpg should get back to normal.
Old Jan 10, 2008 | 04:05 PM
mirebih's Avatar
cool... I'm going out right now do reset the ECU.. I wil let you know what happens. Thanks
Old Jan 13, 2008 | 05:03 AM
mirebih's Avatar
The RPMs have dropped since I reseted the ECU. I dont know why. I only disconeceted the battery for a minute and than connected it again... when i start the car, the rpms go down to 6000 and then after few seconds go back to normal... i'll see how long this will last.
Old Jan 13, 2008 | 06:01 AM
Mad_SB's Avatar
I've got a stock 8 cat sitting in my basement. After you get a price from mitsu for a new one, pm me. I'll ship it to you for $100.
front 02 sensor could be going bad, causing the drop in mileage and fouling out the cat causing the cat inefficiency code. (though I don't recall which way the 02's tend to fail, as in causing the car to run lean or run rich when they start to fail)
Old Jan 13, 2008 | 11:59 AM
mirebih's Avatar
This week I'm going to shop to check what it is, and if the problem is in cat, I wil Pm you.. THanks..
by the way I like your number of posts( Drives: lightning yellow EVO VIII
