Evo 6,8,9 engine in evo 1
Old Jan 14, 2008 | 04:08 PM
downtime's Avatar
Yes,i did a search.I wanted to know if a evo 6,8,9, engine would fit into a evo 1?Could it drop in or are we talking major swap here?
Old Jan 14, 2008 | 06:39 PM
Yogi_B's Avatar
The evo4+ engines were rotated 180 degrees compared to the evo1-3 engines so while yes it is possible to drop later engines in you will most likely have to make new mounts.
Old Jan 15, 2008 | 02:09 PM
Bimmubishi's Avatar
You'd be better off mounting the entire subframe assy from the later car to your early evo. The engine will be cradled correctly and you'd only have to worry about 4 or so mounting points for the new subframe. In the rear you could do the same. It would be expensive but it would be the easiest route to do this kind of project. The car would be about 1 inch wider, it would have aluminum suspension parts, updated hubs and a better drivetrain (with worse gear ratios)
Alex
Old Jan 15, 2008 | 02:11 PM
EVOlution561's Avatar
I'm not talking like an expert or anything but is it really worth it?
Old Jan 15, 2008 | 06:35 PM
fimotorsports's Avatar
i wouldn't say it is worth the trouble.. the 4g63t in the evo1 or in dsm's have been proven
