GM Boost Solenoid Question
Old Jan 15, 2008 | 06:15 PM
03RRVIII's Avatar
were you guys able to control the boost without any boost pills, do you guys get any boost spikes?
TIA
Old Jan 15, 2008 | 06:24 PM
scheides's Avatar
EvoM Moderator
Check the ECUFlash forum.
No spikes, no pills, 26psi from ~3000-6300rpms, then it falls off to ~23-ish by 7600.
DO IT!
Old Jan 15, 2008 | 07:06 PM
03RRVIII's Avatar
DO IT!
i found one thread there but he uses a boost pills, and its an IX, mine is VIII
Old Jan 15, 2008 | 07:18 PM
denny424's Avatar
Where do you get this boost solenoid at? Link?
Old Jan 16, 2008 | 07:30 AM
accident's Avatar
just go to your local chevy gm dealer and order part number 1997152
and if you want the pigtail go to your local junkyard and cut a pigtail off of a later model gm for the egr valve or washer pump motor
ed
Old Jan 16, 2008 | 07:50 AM
taavisev's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=276674
HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid - Evo_Kid
there it is!
