awd system going out?
Old Jan 21, 2008 | 03:07 PM
90GSX-03EVO's Avatar
My car is stock and I spin the front tires when the turbo spools on a cold day (snow tires). Going around corners under boost will tell you if the AWD is dead. By the way, it's not.
It's also not a good idea to try and chirp your tires when going from 1st to 2nd by letting the clutch out fast and slamming on the gas.
Don't launch the car and don't bang gears.
What the hell is a Stage 3 clutch?
Old Jan 21, 2008 | 03:12 PM
RedLanEVO's Avatar
Originally Posted by evo8fate
yes because the car starts to slide and the clutch is a stage three forgot to put that in the description
stage 3? what does that mean?
open diffs are not uncommon to slip the wheels. by slipping the wheels, i mean the torque will stop going to that wheel that is turning/not turning at the same rate as the other wheels...on the other hand, limited slip diffs are limited to slip hence the name. only a certain amount of torque still goes to the wheel that is turning at a different rate. locking diffs will not cut down the torque to the wheels when it senses different speeds.
03 does have open diff..if you have one wheel slipping, torque will be transfered evenly to the other 3 wheels.
anyways, i doubt anything i going out..u still have all 4 wheels turning which means torque is still applied to it from the engine...if anything, you would hear noise..maybe its just the cold weather?
Old Jan 21, 2008 | 03:15 PM
evo8fate's Avatar
im sorry its the act2900
Old Jan 21, 2008 | 03:29 PM
prj.evo's Avatar
open diff with all those mods...doesnt suprise me that it might spin a little occasionaly
There's nothing wrong with your car. It's the cold weather that's causing the wheel slippage (your tires are cold and so is the road which causes less grip). You're probably feeling a bit of torque steer as well, huh?
Old Jan 21, 2008 | 03:32 PM
evo8fate's Avatar
yea i feel that a good bit i really hope its just the cold weather which alot of people are telling me that so im guessing thats all it is
Old Jan 21, 2008 | 06:50 PM
DSM GSR04's Avatar
If wheels are spinning, that is a indication that power is being properly transfered through the drive train, now if you were bogging and loosing power then you have a problem.
Old Jan 21, 2008 | 06:54 PM
BBS's Avatar
BBS
im not sure im new to the car i will have to look it up and find out but it never did this before and i had the car for a couple months now and it never did this before.
i only launched the car three times at the track last year and the tranny and xfer case were just rebuilt and they said the diffs looked fine and didnt need to be replaced.
So which is it. Had the car for a couple of months or you've had the car for atleast a year? Put the car on a lift, turn it on in gear and see if you're wheels spin.
Old Jan 21, 2008 | 06:59 PM
Why not just leave the car in neutral on that lift with no handbrake set and rotate one wheel by itself and see what the other wheels do?
PS: He could have bought the car in October of last year, went to the track a couple of times, saw some problems recently, and posted about them now. That would explain how he owned the car for just a few months but yet still launched a few times it last year.
Old Jan 21, 2008 | 07:45 PM
evo8fate's Avatar
bought the car in july of last year went to the track in august
Old Jan 21, 2008 | 08:30 PM
barneyb's Avatar
This reminds of a guy who wrote once saying, "When I step on the clutch is the entire transmission supposed to move?" No, that's not you problem but it is a good idea to keep the tranny bolted to the engine.
Old Jan 21, 2008 | 09:33 PM
EvoRecordSetter's Avatar
its not the front wheels spinning if the car slides side to side, that means your rear wheels are spinning. the front would have you continue forward not side to side. the rears, make the car go side to side.
car is fine
Old Jan 22, 2008 | 01:09 PM
evo8fate's Avatar
ok thanks for all the help guys
Old Jan 22, 2008 | 02:38 PM
mitdrx's Avatar
I had those exact same issues. It all started like that and then a month later it was harder to get going in first and then second. Everyone told me....its the cold weather. I also have an 03 and the coupler inside the transfer case went out. There was no death wine because the ring and pinion are fine. A month later I could go nowhere.
Old Jan 22, 2008 | 02:59 PM
rice_rocket88's Avatar
Yes I'm sure it's your rear tires spinning... take it easy out of a parking lot/turn, then hammer it... if the tail kicks out, it's definitely your rear tires spinning.. and your AWD is working fine I can literally do this, even in 2nd gear, heck even in 3rd. I can get on it and it's going fast, but as soon as the turbo kicks in, all hell will break loose...
