Mini battery dies after storage..help!
Subscribe
Jan 25, 2008 | 06:44 AM
I have the deka etx14 which is pretty much the same as the braile mini racing battery.. i never had any problem with it until now... i went on a 2 month trip and came back noticed the battery was dead...i tried jump starting it and car started right up...voltage at the battery was at 14.5V+..i left it running and drove around for atleast 45minutes to make sure its charged...the moment i turn my car off...the battery dies again...i get about 0.5 volts instantly out of the mini battery...any ideas?? the battery is shot???
Reply 0
Jan 25, 2008 | 06:47 AM
How old is it? Might need to drive around for more than 45 mins. I drive my Evo once or twice a week and it has a mini battery. It sits in an uninsulated garage and it is tough to crank when I go for the weekly drive, but it fires up everytime. The battery is almost 2 years old (Odyssey) but still seems to work great.
Reply 0
Jan 25, 2008 | 06:52 AM
mine is only few months old...maybe 4 months??? the weird thing is the battery drains completely in an instant after car shut off...
Reply 0
Jan 25, 2008 | 06:57 AM
Wow, only 4 months old? My battery sat for 2-3 months over the summer and it still cranked the car up.
I'd go on a long trip or put on a trickle charger to fully charge the battery. Could also go to Autozone and see if your alternator is putting out the proper amperage.
Reply 0
Jan 25, 2008 | 07:00 AM
it sat 2 months over cold winter...i had no problem in summer time..
Reply 0
Jan 25, 2008 | 08:37 AM
i droved around for another 1/2 hour...the moment i turn my car off..the battery dies...
Reply 0
Jan 25, 2008 | 08:56 AM
lots of threads of battery relocation lately...i'd recommend that...you're going to have nothing but problems, especially in the cold.
Reply 0
Jan 25, 2008 | 08:58 AM
yup thats why I kept my stocker and moved it too the trunk
Reply 0
Jan 25, 2008 | 09:01 AM
Mine drained completely when I let the car sit for about a month. Not cold weather or anything...just that you can't leave these sitting AND connected. So I've got mine disconnected right now since it's cold, and I'm using my Blazer. When I daily drive her...no problems.
Though I've never been stranded ::knocks on wood:: I don't like the odds right about now after all these threads have been popping up.
Where do you guys get your relocation kits from?
Reply 0
Jan 25, 2008 | 09:11 AM
summit racing luckily for me they are 5 miles down the road from me so i dont have to have crap shipped!
1 gauge power and ground kit cost me about 70 and i just picked up a tray instead of doing a box, maybe ill do a box later. Very easy thing to do and, imo, the best thing ive done.
Reply 0
Jan 25, 2008 | 09:18 AM
yea, I saw the kit there on Summit. I would probably do the box if I did it, I wonder how they go about venting it...because I wouldn't want all the battery fumes just sittin' in there.
Did you mount yours on one side or the other or right in the center behind the seats?
Reply 0
Jan 25, 2008 | 09:22 AM
i dont think venting is a huge issue, especially if you go with dry cell. To vent, they have a tube that comes from the box..not sure where you route it since i didnt do it obviously, but they have a solution for what you want.
i mounted mine on the passenger side, next to the winshield washer fluid resevoir.
Reply 0
Jan 25, 2008 | 09:31 AM
My mini battery dies every winter. Just letting the Alt try to recharge it is not the same as a slow trickle type charge. The alt is designed to maintain a charge in the battery not to recharge a weak battery. there is also a state or health test for a battery not just a state of charge. Also real quick if you over tighten the cables it can damage the seal at the terminals and cause the battery to leak vapors causing a dead cell in side the battery, AMS has a tightening spec on the webpage on how tight to make them.
Reply 0
Jan 25, 2008 | 10:42 AM
u need a battery tender (got it on ebay for $45ish shipped) if you're going to leave it for more than a week or two in the winter. I drive every day or at most i go a 2 days without driving, and my braille (deka) mini batt cranks like a champ.
Reply 0
Jan 25, 2008 | 10:52 AM
Quote: My mini battery dies every winter. Just letting the Alt try to recharge it is not the same as a slow trickle type charge. The alt is designed to maintain a charge in the battery not to recharge a weak battery. there is also a state or health test for a battery not just a state of charge. Also real quick if you over tighten the cables it can damage the seal at the terminals and cause the battery to leak vapors causing a dead cell in side the battery, AMS has a tightening spec on the webpage on how tight to make them.
I think the tightening spec on the website is for the terminal STUDS, not the cables...
Reply 0
