relocation ?s
Old Jan 29, 2008 | 06:16 PM
amscrazy's Avatar
relocation ?s
so you guys have probably seen if you look at evo general frequently...that i just relocated a yellow top to my trunk...i have 2 questions....
1. do i need some sort of relay/fuse on the 2 gauge wire that runs from my positive terminal to teh positive bundle in my engine bay....i hear that i did...but i dont see why because i still have the sotck positive battery bundle
2. i dont have my red cap that came on the positive bundle anymore...no idea where it went...is there a way i can protect the positive bundle from the elements and from hitting metal and sparking and shorting...can i just tape it up
Thanks
Old Jan 29, 2008 | 06:18 PM
rice_rocket88's Avatar
You certainly need a fuse between the battery and the engine bay.. now between the engine bay and the harness.. you could always add another one, but the key is the one from the battery to the wires
As for the red cap, go to any autoparts store and you can buy a variety of caps.
Old Jan 29, 2008 | 06:31 PM
amscrazy's Avatar
so can i go out and buy a fuse for the 2 gauge because alot of kits dont come with them...is there a certain one...and can i just cut the wire in a spot and splice it in
and if i can go buy one...where can i...or can u tell me somewhere on the internet i can buy a 2 gauge positive wire with one already in it
Old Jan 29, 2008 | 07:46 PM
Evo8zip's Avatar
i didn't add another fuse. if the one in there is good enough from the factory its good enough for me. And i electrical taped the crap out of the bundle. Not to the point where its bulging and obnoxious, but its not going to short out on anything. I'd check your local car stereo place for the cable you are looking for.
Old Jan 29, 2008 | 08:17 PM
Jameson_IXMR's Avatar
I use a small battery myself, but I know alot about batteries in general. I am assuming the yellowtop is a SLAB (sealed lead acid), and therefor should have some means of venting, typically just having it in the trunk is okay for normal driving. I would seriously enclose the entire battery. Those red clips fall off. I would get some cheap sheet aluminum (few dollars) and bend a box housing for it, then coat the inside with a rubber coating and mabye carpet the outside. Get the OEM carpet mat thing that sits over the spare-tire well and use that to carpet it.
Old Jan 29, 2008 | 08:22 PM
Celica2EVO's Avatar
As for the fuse, just go to a car audio place such as Best Buy or along those lines and get a 2 ga. Inline Fuse for a amplifier. Tape the crap out of the bundle and it will be fine.
Old Jan 30, 2008 | 11:33 AM
amscrazy's Avatar
I have the batttery enclosed completely but there are hole at the top for venting
as for the fuse, is there a certain amp i need...my friend recomended a 150amp....i want the power to be able to flow...but i want it to break with a short
MasterCope
Lancer Tranny/Drivetrain Tech
Aug 27, 2016 06:12 PM
NoReason
Jun 7, 2015 07:05 AM
hkfeet
For Sale - Miscellaneous Automotive
Aug 2, 2005 09:20 AM
RENN-ART
Jan 13, 2004 12:10 AM
