Identify this grinding noise...
Old Feb 10, 2008 | 02:34 AM
recompile's Avatar
I don't have a sound clip, but I can try to get one...
I get a grind from the right front pretty regularly.
1) It happens when starting to move from a standstill or while slowing down from a slow speed.
2) It is most apparent in the morning when I first drive the car, and does not happen every time.
3) It has happened both with clutch engaged and with it disengaged
4) It seems to be speed/wheel dependant
5) If I had to describe it what it sounds like, it sounds like a grinding gear although higher pitched
Thanks in advance!
Old Feb 10, 2008 | 03:21 AM
18bora's Avatar
Maybe from surface rust on the rotors?
Old Feb 10, 2008 | 05:18 AM
recompile's Avatar
I don't think it's that, but it could be rotor/brake related as I am in need of a brake job
Old Feb 10, 2008 | 05:24 AM
dsmjeffro's Avatar
prolly just a brake noise
Old Feb 10, 2008 | 07:53 AM
MitsuJoe's Avatar
Speed dependent could be your wheel bearing. Although a lot of moisture building up on your rotors could cause this noise. Does it go away when you use the brakes?
Old Feb 10, 2008 | 08:02 AM
gsrboi80's Avatar
I bet you inner pads on one of your front wheel are down to the fellers and its scraping against your rotor
