Evo IX MR 2006 Slugish...?
Theyre correct. You need to ditch that BOV, put the intake on and give me a shout to get it tuned =-)
By the way the Walbro isn't needed at your power level, I'm not sure what your plans are with the car. At this point and time you don't need it.
Cheers!
Cheers!
it's "idle" not "ideal" please use correct English.
Why would you change out your stock metal diverter valve? obviously you are not running high boost. is it recirculation type? if not, it will make the car run rich between shifts. if you are running 25psi like I do, then you should look into APS bov which holds boost and release some pressure to the open.
And please, use comma in your sentence.
"any 1 need a SQV BOV"
It never stops!
you don't want people to think that you are not educated and drive a $30k car. Also, it helps member to understand what you are trying to say.
