Evo IX MR 2006 Slugish...?
Old Feb 14, 2008 | 09:35 AM
  #31
06MRV8Killer's Avatar
What would be saved in the ECU that resetting it would fix?
Old Feb 14, 2008 | 12:56 PM
  #32
Anyone?^^
Old Feb 14, 2008 | 02:13 PM
  #33
Drooke's Avatar
i have no clue
Old Feb 14, 2008 | 02:20 PM
  #34
EVO IXMR's Avatar
Originally Posted by 06MRV8Killer
What and how do you reset a battery. Do you mean take the terminal off to reset the ECU like a honda? That doesnt make sense..
yea just reseting the ecu...i had a similar problem and that solved it thats why i just threw it out their
Old Feb 14, 2008 | 02:40 PM
  #35
Burklow's Avatar
Resetting the ECU will return your adjusted timing back to stock setup. It's a good idea in case any of it was pulled, thus a loss in power. It is like a vehicle's safety defense mechanism.
I don't remember if Evo ECUs have a "safe mode" or not. Anyone clarify this?
Old Feb 14, 2008 | 03:00 PM
  #36
Drooke's Avatar
ya i think some of my timing stuff is messed up my car sounds like a loose pulley or belt at idol
Old Feb 14, 2008 | 03:10 PM
  #37
Yeah but what if you are tuned
Old Feb 14, 2008 | 03:17 PM
  #38
Drooke's Avatar
no it wont reset ur tune ur tune is saved in a diff part of the ECU
Old Feb 14, 2008 | 04:56 PM
  #39
andrewzaragoza's Avatar
the ecu remembers the codes that it has pulled until it is removed via a code scanner or if you reset the ecu. when reseting the ecu you also remove the short & long term fuel trims that the ecu has learned.
Old Feb 15, 2008 | 06:54 AM
  #40
Drooke's Avatar
just to let u guys know I put my intake on with the stock bov it runs so much better thanks for all the help now I just need a tune
Old Feb 15, 2008 | 06:55 AM
  #41
Burklow's Avatar
Glad to hear!
Yeah a tune will work miracles on Evos.
Old Feb 15, 2008 | 07:01 AM
  #42
Drooke's Avatar
yup Im hopping to make over 300whp with my mods
Old Feb 15, 2008 | 10:29 AM
  #43
......... which means what? It seems like you stopped in the middle of explaining it or I am just not getting it. Can you elaborate on this a little bit more. Thanks
Old Feb 15, 2008 | 10:37 AM
  #44
DJ Brett B's Avatar
Ahh, good to see you put the stocker back on!!! A lot of people make the mistake of putting on a VTA with no tune and wonder where the power went... Do you still hear any strange noises or did that problem resove itself with the BOV?
Old Feb 15, 2008 | 12:58 PM
  #45
Drooke's Avatar
Ya the only other problem was a loose belt my car is running good and now I'm just waiting for a tune
