Real quick
Old Feb 13, 2008 | 06:38 PM
randomae's Avatar
Real quick
I am looking to buy a stock evo 9 turbo from a member but i am unsure if i need to buy an install kit. FP has an install kit for their Green turbo which from the outside is an evo 9 turbo which would lead me to assume that i would need that kit in order to do the conversion. How true is this?
EDIT: Just to clarify this in going on a 2005 evo 8.
Old Feb 13, 2008 | 06:57 PM
JDMCT9MR's Avatar
Yes you will need an EVO 9 turbo install kit for an EVO 8.I think bushur sells one as well.
Old Feb 13, 2008 | 07:31 PM
gsrboi80's Avatar
All you really need is a IX outlet pipe. If you get the Buschur Kit which I got the only issue is that there is no nipple for a boost source on thier Outlet pipe. So you'll need to T the BOV line or drill the pipe and install a fitting.
Old Feb 13, 2008 | 08:31 PM
randomae's Avatar
to avoid having to "install a fitting" the FP version would suit my needs correct?
Old Feb 13, 2008 | 08:36 PM
Drooke's Avatar
yes it should GL with the build
