5000 mile service
Old Feb 19, 2008 | 11:24 AM
boostedspra's Avatar
5000 mile service
Hey guys I tried real hard searching for it but I can't find it.
Can you gus tell me the part numbers and what they are called for the transmission gear oil, LSD oil, and T-Case oil so I can get them and change them at 5k. Also is there anything else I should do I a changing the oil also w/ mobil 1 fully syn 10w-30. Is that all??
Old Feb 19, 2008 | 11:31 AM
Infinity's Avatar
Huh? 5K Mile service?
I'm only aware of the 30K and 60K mileage service intervals besides the 5K Engine Oil Changes.
Old Feb 19, 2008 | 11:44 AM
cheb evo's Avatar
Here is a link to the Diaqueen: http://www.mitsubishiparts.net/catal...ction=598#1498 For the tranfer case and re differential.
For the Oil, you can go your own way, but I use either AMSOIL ATM 10W30 or Mobil 1
For the Tranny, I always use https://secure.buschurracing.com/cat...roducts_id=825 with no issues.
This should really be all you need with the exception of rotating tires...
Old Feb 19, 2008 | 11:46 AM
eckorex's Avatar
check out this thread from last week
https://www.evolutionm.net/forums/sh...light=diaqueen
Old Feb 19, 2008 | 11:58 AM
Ralliart03's Avatar
Check with Russ at mitsubishiparts.net They are a vendor on here, Russ will take good care of you.
grillpt's Avatar
Some other will disagree with me but I personally feel your throwing your $ away when you change your Trans/TC and diff oils so often. 30K intervals is what's recommended per owners manual.
Old Feb 19, 2008 | 12:07 PM
Erik@JNZtuning's Avatar
Daiqueen diff/xfer PN 3775610
Old Feb 19, 2008 | 12:54 PM
I've just always heard 5k for the first change
Old Feb 19, 2008 | 12:56 PM
Turbolover's Avatar
That is correct, then every 10-12k depending on your driving style and conditions.
oh yea and if you guys didn't see my sig it is for a MR 6-speed tranny so I know this is a different fluid then for the 5-speeds
Old Feb 19, 2008 | 12:58 PM
Thanks man just confirming since someone above said don't do it at 5k?? I feel this is important due to break in of tranny, rear, and t-case even if it wasn't recomended
Old Feb 19, 2008 | 04:44 PM
itsme4g63's Avatar
same ****zo.
Old Feb 19, 2008 | 04:48 PM
chaotichoax's Avatar
Originally Posted by itsme4g63
same ****zo.
it's not the same in the least
Transmission fluid –
Diaqueen Super Multi-Gear Oil 75W-85 (Part # - MZ313376)
Transfer Case and Rear Differential fluid –
Diaqueen LSD Gear Oil (Part # - MZ3775610)
Old Feb 19, 2008 | 04:58 PM
itsme4g63's Avatar
I meant after-market wise.
Old Feb 19, 2008 | 05:33 PM
Oil Doc's Avatar
Engine oil... AMSOIL SSO 0W-30... Second Choice AMSOIL ATM 10W-30 Both are Products formulated to run in Turbo Powered engines.
Transmission, 5 and 6 Speed: AMSOIL MTG Synchromesh Fluid.
TC and Differential: AMSOIL SVG Severe Gear Lube
Filter WIX.... 57092 or 51356 Depending on year
Email me for a complete package dropped on your door.
oildoc@bestoil4you.com Toll Free Ordering at 1-877-356-6099
Somebody said they are running a 50 wgt ? I'd be concerned about shortening your Turbo life from possible oil starvation... Mits recommends a 30 wgt.
Doc
stanlsha
Jul 12, 2011 04:04 AM
croy75
Lancer Engine Tech
Dec 20, 2007 08:10 AM
ShiftySVT
Jun 19, 2006 11:27 AM
gregivq
Dec 26, 2004 11:34 AM
runny_yolk
11
Aug 25, 2003 02:50 PM
