Rear Diff Lube ????
Old Feb 23, 2008 | 08:51 AM
rio-evo's Avatar
Exclamation Rear Diff Lube ????
What type of rear lube can I use without compromising the gears?
I also need to know if I can purchase at Advance Auto or equivalently.
Thanks,
Old Feb 23, 2008 | 08:52 AM
grillpt's Avatar
SEARCH please...
Old Feb 23, 2008 | 09:23 AM
fimotorsports's Avatar
I would stay with the stock lube diaqueen, I had some bad luck with redline shockproof, put stock fluid back in and worked like new again.
Old Feb 23, 2008 | 09:24 AM
EvoooB's Avatar
+1 on search button.. DiaQueen LSD Gear Oil
Old Feb 23, 2008 | 10:08 AM
RussellM's Avatar
Plat Vendor
Part Number 3775610 - Diaqueen LSD Fluid
Old Feb 23, 2008 | 10:13 AM
Nkryptd1's Avatar
Diaqueen is the best way to go, especially if your "Factory Warranty" is still in tact.
Old Feb 23, 2008 | 10:20 AM
Kracka's Avatar
Stock OEM Mitsu
Old Feb 23, 2008 | 12:27 PM
barneyb's Avatar
The transmission is picky about oil. The transfer is very picky concerning what oil you put in it. The rear axle, as long as the oil is for a limited slip unit, any gear oil from Advance Auto should be fine. The things is, if you are changing lubricants, you are going to need Diaqueen for the transfer and it also works in the rear axle. So, use Diaqueen.
Old Feb 23, 2008 | 12:36 PM
m98evolution's Avatar
+1 for the Mitsu Diaqueen, checkout mitsubishiparts.net
Newuser213
Dec 4, 2016 05:15 PM
emperor496
30
Jan 24, 2014 07:46 AM
njvlllrs
Aug 6, 2009 10:12 PM
BenM
May 24, 2004 06:23 PM
kanned
Mid-Atlantic Region
Aug 18, 2003 03:03 PM
