New Clutch/Flywheel, then boom?!
Old Feb 23, 2008 | 08:42 PM
FloopyDisk's Avatar
I recently went to a shop and got the car's clutch/flywheel installed (HDSS and Gruppe-S) , and everything was fine for a few hours, a little easy to push down the clutch though. Anyways, in third gear around 4K rpm, I hear a big BOOM, the car instantly looses power. and I stopped and it's dead. When I tried to turn it back on, horrible sound then it instantly shuts off...am I right to think it's the clutch and flywheel install? Or was it something worse? (Sorry, didn't know what to search for this issue.)
Old Feb 23, 2008 | 10:00 PM
evozakk's Avatar
What kind of sound? It must hav been brought on by the install. I don't see how that could be coincidential.
Old Feb 23, 2008 | 11:12 PM
FloopyDisk's Avatar
It was like a huge popping sound.
Old Feb 23, 2008 | 11:17 PM
staatz's Avatar
IC pipe could have popped off.
Old Feb 24, 2008 | 12:22 AM
ballallday89's Avatar
Check your IC piping, mine did that by the intake manifold(top of the engine)
Old Feb 24, 2008 | 07:13 AM
FloopyDisk's Avatar
Nah, I popped the hood, the upper IC pipe was good. As for the lower one, I'm not sure. It seemed fine. The pop sounded like it was under the firewall.
Old Feb 24, 2008 | 07:22 AM
Evo9tunerz's Avatar
If it is a licp you should be able to drive, just not boost.
Old Feb 24, 2008 | 07:32 AM
FloopyDisk's Avatar
Wasn't able to drive...so hm...
Old Feb 24, 2008 | 07:45 AM
cssaddictm4's Avatar
How does the shifter movement feel? Have you tried starting it in neutral? Does it die with the clutch in or out? Maybe that extra clamping force blew the IC piping off Double/tripple/quadruple check the IC pipes.
Old Feb 24, 2008 | 07:57 AM
FloopyDisk's Avatar
It does start in neutral, but I'm not sure if it dies in or out. The car is at the mechanic that installed the clutch/flywheel, so, I can't really check anything on it.
Old Feb 24, 2008 | 08:24 AM
Guz Man's Avatar
well lets us know what your mechanic says.. coz i got the same exact clutch combo, didnt install it yet.. but very very curious of the cause of your problem with the car..
Old Feb 24, 2008 | 09:26 AM
FloopyDisk's Avatar
I will let ya'll know. I just couldn't see why it would pop like that after a clutch/flywheel install.
Old Feb 24, 2008 | 10:22 AM
Possibly no oil in the trans after install.
Old Feb 24, 2008 | 11:49 AM
evozakk's Avatar
How so?? The MAF is on the intake.. If its an IC pipe it would start but not run. It happens to me alot, it starts but stumbles and dies. As for the noise, I would be calling up the mechanic.
Old Feb 24, 2008 | 01:13 PM
FullOutPwr's Avatar
I had an IC pipe blow off @ 28 psi and it would run, just run like crap. I may be wrong in this assumption, but it'll read whats going through the maf into the turbo and will also see the 02 sensor and attempt to make adjustments from there...
