Got my car towed on 2 wheels
Old Feb 27, 2008 | 12:03 PM
4WS Tuning's Avatar
Good luck trying to get them to pay.... I had a customer with the same problem a year ago and hes still fighting it... I dont remember the exact damaged parts..
Cheers!
Old Feb 27, 2008 | 02:21 PM
04Evo8's Avatar
Would this cause damage if it was an VIII with the open front differential?
Old Feb 27, 2008 | 02:42 PM
V1RGINEVO9's Avatar
Someone needs to make a sticker that says
(if you don’t use a flat bed to tow my car, I will sue your as*)
(or)
(No flat bed = law suit), or something along these lines
Old Feb 27, 2008 | 02:57 PM
evo_domination's Avatar
Originally Posted by RevMoto
It is in the system of what drivetrain it is. The tow company is completely responsible for it. I wouldn't even waste time and let your car possibly get damaged even more. They should know better. Evo's get towed all day.
+1
My cousin works for a tow company and he told me that if the driver doesn't follow the manufacturers recommended requirements for towing a vehicle that the tow company is fully liable. It's in the owners manual about how to properly tow an evolution, therefore, that's how recommends it should be done. I'd go after the tow company immediately! You shouldn't have to pay for there dumb **** ignorance!!! They hurt your investment, make them fix it.
Also, anytime your car has anykind of interaction with a tow truck, take pictures. Always, cuz you never know.
Old Feb 27, 2008 | 03:00 PM
TaiwanEvo's Avatar
ya i took pictures of it.. so i think i will be good
Old Feb 27, 2008 | 03:05 PM
BocaShula's Avatar
Originally Posted by lilman8403
i did the same thing and parked in a teachers spot in the parking garage, the car was backed in and so low that they could not get the dolly under it and the gargage was not tall enough to get a flat bed in so i just got a ticket and parking for the day!!! (moral of the story is lower your car so much that no one can tow it)
I think your car is fine but maybe a four wheel alignment and balance is in order.
nice.
Old Feb 27, 2008 | 03:09 PM
Speed Element's Avatar
These are what you need to avoid getting towed on 2 wheels.
Click here to order
Old Feb 27, 2008 | 03:27 PM
^+1!!!!!!!!!! I have one. Put it right by the VIN!
Old Feb 27, 2008 | 03:48 PM
hk2ronin's Avatar
I have the bright yellow lancer shop one near my vin number on the dash. I even got it laminated and velcroed it to the dash.
Its the towing companies resposibility to know what cars are awd. When audis first had quattro towing companies towed them on two wheels not knowing they had awd. There was a big uproar and the towing companies had to pay for the damages.
Take your pictures and your owners manual(section about towing) and show the tow company these items. Tell them that they will pay for damages or you will call your lawyer, local news stations, and your local paper and that they will get these items and the complete story. I'm sure after that they will fork up the repairs.
Old Feb 27, 2008 | 03:51 PM
tvbf1's Avatar
If you got your Evo towed 2 wheel then most likely your Transfer Case is jacked up. It'll drive fine, but if it smells like tranny fluid inside and all of your ACD lights are lite then your TC is gone.
Old Feb 27, 2008 | 05:20 PM
TaiwanEvo's Avatar
i have an 03 evo so no acd.. so how can i check if my transfer case is jacked up??
Old Feb 27, 2008 | 05:27 PM
eckorex's Avatar
that speed element one is cool but I don't want the sticker on the outside
Old Feb 27, 2008 | 05:30 PM
Evoryder's Avatar
Originally Posted by WVUmaniac
where would you put that sticker?
Old Feb 27, 2008 | 06:50 PM
EVO8emUp's Avatar
Transfer case should be fine. Its the center diff that takes the abuse. I've seen a center diff that was welded together b/c it overheated from being towed. That was on a Galant VR4 though.
Change the tranny fluid.
Old Feb 27, 2008 | 10:34 PM
Jameson_IXMR's Avatar
My yellow sticker has a tiny little evo on the back of the truck. Wing and all.
and its backwards static-cling. So it's actually inside the car, but stuck to the glass (should last forever).
