Power Steering Help!
Old Mar 3, 2008 | 05:46 PM
Celica2EVO's Avatar
Ok, so I just got my car finished after working on it for about 2 months. Wekk when I fired it up, everything sounds great besides the Power Steering is making a LOUD whining, and fluid is pouring out of where the line with the single bolts is at! Im pretty sure its the return line that is hooked to the resevoir! When I pullud the line off, the inside is stepped like there should be an o-ring in there or something, but nothings in there and it is just draining fluid! So is there supposed to be an o-ring in there, or what is causing it to whine and pour fluid out? Thanks!
Old Mar 3, 2008 | 07:26 PM
EatSleepBoost's Avatar
i just lost power steering last night. i have no assist but the fluid level is ok. i am goin to check it out tomorow but it could be a common problem. i wll try n get back to u tomorow
Old Mar 3, 2008 | 07:30 PM
dustin03's Avatar
The whining sound is the power stearing straing to push the fluid through it.
Old Mar 3, 2008 | 07:34 PM
xiaoni420's Avatar
I have a similar issue but it's not as bad as yours. Mine takes some time before it starts to make that whining sound. I just refill it with more fluid and it keeps for some time. I will take it in soon though to get the problem fixed.
Old Mar 3, 2008 | 07:43 PM
bsander's Avatar
Is it a new power steering pump?
Old Mar 3, 2008 | 07:52 PM
Celica2EVO's Avatar
no, its the stock power steering pump. We had to take it off in order to take the motor mount off. And after we put it all back on, for some reason it started leaking really bad out of where the return line hooks in, and making a bad whining noise. It was working perfectly fine before though.
Old Mar 3, 2008 | 07:55 PM
BBS's Avatar
BBS
If its the pressure return line going into the resevoir, then yes you need an o-ring in there. Get one in there quick before you burn out the steering pump and cause more damage.
Old Mar 3, 2008 | 08:13 PM
Celica2EVO's Avatar
thats what i figured! thank you for your comment! it only ran for maybe 3-4 mins tops, and maybe 6 full revolutions of the steering wheel, and there is still plenty of fluid in there so it shouldnt have hurt the pump! is the whine just the pump trying to shove the fluids back through all the lines that have drained?
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
fireroasted
Sep 4, 2014 06:25 AM
5LEEPERISAH23I
31
Nov 20, 2013 08:39 PM
Lexus01IS
10
Mar 15, 2013 06:56 AM
USP45
May 8, 2007 03:27 PM
