THINKING TO PUT 'SARD CATALYTIC CONVERTER'... someone help
Old Mar 4, 2008 | 10:05 AM
S6devil's Avatar
I have an Evo IX. I have a full TBE. it was very loud so i changed the regular test-pipe to a Megan resonated testpipe. now, there is a loud rattling/vibrating noise coming from underneath the car, and it rattles the stickshift and handbrake handle.
So, I need to change it our again. I found this product (an aftermarket catalytic) - i think it will solve all my issues. it will take away any vibration that the Megan resonated pipe is causing and any rattling associated with it. it will also make my overall exhaust quieter, as i wanted to do in the first place (btw, i dont mind losing a couple hp)
SO, does anyone know about this particular product? is it good? reliable? will it help with my issues?
http://cgi.ebay.com/ebaymotors/SARD-...spagenameZWD1V
Old Mar 4, 2008 | 10:14 AM
tony_b's Avatar
Why not just find out what it's hitting and "fix it" rather than change parts, spend money, lose hp??
Old Mar 4, 2008 | 10:17 AM
Red Sox's Avatar
BR's hfc is cheaper. IDK if it is compatible with your exhaust, but I'd call them and find out.
https://secure.buschurracing.com/cat...70a980f3450cb9
hotrod2448's Avatar
I will be very surprised if that is an actual SARD cat. Those things were @ $1K dollars a few years ago.
Also, when I went from an HFC to straight pipe my car got quieter everywhere but, WOT. In my experience most HFC's drone really bad.
I agree with tony b. Get under there and fix what's rubbing. I had to remove one of the heat shields.
Old Mar 4, 2008 | 10:20 AM
72Tornado's Avatar
Just get under there and find out what it's hitting. The idea of paying $490 for a cat is beyond hilarious
Old Mar 4, 2008 | 01:10 PM
S6devil's Avatar
if i could just get under there, i would. obviously only someone 2" tall can get under there. just going to a shop and putting it on a lift is gonna be $50,and another $50 to fix the rattle. and when its said and done, the exhaust is still gonna be loud which was the first problem to begin with. i thought this megan pipe will solve it, and it only made it worse.
Old Mar 4, 2008 | 01:15 PM
ROGERV's Avatar
It's probably just your heat shield hitting the cat. All you need to do is bang the heat shield away from the cat and your all good.
The Sard cat is a very good cat just like the Apexi Catilyzer, but it may cause the same problem you are having right now.
Old Mar 4, 2008 | 01:56 PM
travman's Avatar
wow that is a lot of money for a high flow cat......fix what you got or get a perrin highflow cat for 1/2 that price.
Old Mar 4, 2008 | 02:16 PM
fostytou's Avatar
EvoM Community Team
Go for the perrin high flow cat
I'm guessing your megan RTP rattle is the same as everyone else's, the O2 sensor hitting the heatshield.
If not, your exhaust may not have been lined up properly and might be hitting something.
Old Mar 4, 2008 | 03:39 PM
S6devil's Avatar
well this is what i did. i bought a small ramp today, and drove the car up to see whats up underneath. the heat shield clears the Megan pipe by several inches, and everything else aligns perfectly.
so this is a mystery for now!
Old Mar 4, 2008 | 03:44 PM
ROGERV's Avatar
What about the 02 sensor ? how far away is it from the heatshield and floor board. I actually had to ding up the floorboard because it was hitting it.
Old Mar 4, 2008 | 04:43 PM
JDMCT9MR's Avatar
+1 on the Perrin HFC.
Old Mar 4, 2008 | 07:53 PM
S6devil's Avatar
call me crazy but there is no O2 sensor. the hole where it goes is patched up.
am i blind ? am i looking at the wrong thing ??
Old Mar 4, 2008 | 08:04 PM
72Tornado's Avatar
Are you sure your downpipe isn't rattling against the crossmembers? That's what my issue was...fixed it by buying an RMR brace that can accommodate larger DPs.
Old Mar 4, 2008 | 08:12 PM
Evo Izzy's Avatar
I had this same issue bro. I installed my resonated test pipe and something started rattling underneath the car. I jacked up my car and it was the heat shield right above the test pipe. I pushed on it with a flathead and it gave me another half inch of clearance. I haven’t heard the rattle since. Good luck.
