The "Official" Evo Modding for Dummies
Old Jul 22, 2013 | 12:57 PM
  #706
tarmacblack03's Avatar
I have referred many new evo owners to this sticky to save a my voice; thank you! lol
Old Jul 22, 2013 | 09:04 PM
  #707
RavioliArt's Avatar
Thanks for the list!
Old Aug 20, 2013 | 12:18 AM
  #708
MR_Ivan_IX's Avatar
Bump great info thanks!
Old Aug 23, 2013 | 06:55 PM
  #709
coreymelton's Avatar
What next evo 8?
Got an 03 evo and not to sure what I should buy it. Just got it a month ago and it has the following
-injen intake and charge pipe
-hmbc boost controler
-custom turbo back exhaust with cat delete
-aftermarket clutch
Now I think the boost is set to around 17 psi.
I'm pretty new so tell me anything
Old Aug 23, 2013 | 07:10 PM
  #710
kaynevo's Avatar
Coilovers?
Old Aug 23, 2013 | 07:33 PM
  #711
Originally Posted by kaynevo
Coilovers?
I've got it on springs
  #712
Viegasjuice's Avatar
-aftermarket clutch
Do you know the history of the car? Is it tuned? I recommend a good wideband.
Old Aug 23, 2013 | 07:34 PM
  #713
That's the thing. The people I got it from doesn't know much. So I have no idea
Old Aug 23, 2013 | 07:49 PM
  #714
Socal's Avatar
Break out the pocket book kid...Get cams, intercooler, injectors, fuel pump, and tune it for ethanol..lol It depends on what you are trying to do with the car. Unlimited options out there. What are your plans?
Old Aug 23, 2013 | 07:54 PM
  #715
evo4life94's Avatar
If your not sure if the car has a tune or not, you should definitely look into getting a tune first.
Old Aug 23, 2013 | 07:55 PM
  #716
r3dtr1ckz's Avatar
boost, wideband and oil pressure gauges.
Old Aug 23, 2013 | 08:00 PM
  #717
hiboost2.0's Avatar
https://www.evolutionm.net/forums/ev...-100-time.html
Do you have a boost gauge and a wideband gauge? As of right now I would recommend doing general maintenance to the car because you really don't know how long it's been since the fluids and all that have been changed.
You can also bring it to a local evo shop and ask their opinion on what they think you should do.
How much power do you want out of the car? Are you going to race it at the strip? Autocross? Road course? Daily driven?
Old Aug 23, 2013 | 08:36 PM
  #718
MRolla's Avatar
maintenance is the timming belt done , plugs wires boost leak test, fluids trans diff transfer case. Then check compression test, and then a good tune if all is well
Old Aug 23, 2013 | 09:23 PM
  #719
rjfg's Avatar
As already said get a wideband and oil pressure etc and chexk your idle afrs and wot afrs and get a tune!
Old Aug 24, 2013 | 06:52 AM
  #720
egis's Avatar
Why you guys tell op to get oil pressure gauge?his engine is not build,he's not pushing 500hp.
