Evo misses and backfires above 5000 rpm
Old Mar 7, 2008 | 01:21 PM
smithc33's Avatar
Hey all,
I drive a 99 evo 6 and just recently its been missin and backfiring once the revs get near 5000 rpm and above, and acceleration isnt smooth. Anything below 5000 rpm and its fine. I havent modified it in any way as of yet. Has anyone else had this sort of problem or know what might be causing the problem as its givin me the ****s
Old Mar 7, 2008 | 01:22 PM
idriveanevo's Avatar
first things first, check or change your plugs.
Old Mar 7, 2008 | 01:29 PM
Silvermike's Avatar
Then check ignition coil/ wires. then loook for fuel pressure ( pump/ filter/ injectors)
Old Mar 7, 2008 | 01:30 PM
Evo IX MR's Avatar
Like he said you probably need to re-gap or change out your spark plugs.
Old Mar 7, 2008 | 01:59 PM
el producto's Avatar
not getting enough fuel maybe?...you should be using 93 octane.
Old Mar 7, 2008 | 03:24 PM
MrEvoVIII's Avatar
weather below 34 degrees Fahrenheit can sometimes cause for a boost spike that can sometime lead to a fuel cut... a boost controller would remedy that if you don't have one already... just another idea.
Old Mar 7, 2008 | 07:56 PM
tdz16's Avatar
I would change out your plugs if nothings been modified yet. If that doesn't work I'd look into fuel delivery/quality issues.
~Tom
Old Mar 8, 2008 | 01:59 PM
smithc33's Avatar
Ok, thanks guys for your replies. Ill change the plugs and go from there. Cheers
akira2_03
21
Dec 5, 2016 01:46 PM
redrocket03
Jun 5, 2013 08:45 PM
BhpTuner
Sep 18, 2010 07:16 AM
Talon_66
Dec 10, 2008 04:53 AM
