momo steering wheel issues?
Old Mar 8, 2008 | 12:59 PM
eaglevo's Avatar
Thumbs down momo steering wheel issues?
has anyone had any steering wheel problems? I have an Evo IX MR momo steering wheel that is falling apart.
Old Mar 8, 2008 | 01:03 PM
newimportowner's Avatar
I had issues with mine. it was like it was finished completly. the seam at the bottom was split and the little pastic caps on the stems werent there. dealer replaced it under warranty.
Old Mar 8, 2008 | 03:35 PM
EVOlX's Avatar
Yeah. the leather in the bottom where it comes together is peeling off. I just try not to rub on it. One of my buddies that used to work fixing car interiors is going to try to fix it, other than that it is fine.
Old Mar 8, 2008 | 04:25 PM
soontobe's Avatar
just the top grip gettin worn away thats all
Old Mar 8, 2008 | 04:27 PM
benniboi08's Avatar
whoa no problem so far. try not to grab it sooo tight when you guys are WOT. j/k I occasionally use leather cleaner on it when I do the interior of my car and its fine for now.
Old Mar 8, 2008 | 05:09 PM
vegasevo9's Avatar
Had mine replaced yesterday through warranty. Had a small crack at the 3oclock section.
Old Mar 8, 2008 | 05:11 PM
phat_bastage's Avatar
No problems on mine either.
Old Mar 8, 2008 | 05:15 PM
Draven83's Avatar
im having problems right now with mine. might see if the dealer will cover it under warrenty. they have been good to me since i started taking it to them.
UPDATE The dealer covered my steering wheel under warenty. and i have a 04 VIII
Old Mar 9, 2008 | 07:02 AM
thejeebus2002's Avatar
NEver had any issues with mine.
Old Mar 13, 2008 | 07:39 PM
boostedspra's Avatar
mine seems like it is going to peel before long down at the bottom
Old Mar 13, 2008 | 07:41 PM
JKD's Avatar
JKD
I have absolutely no issues with my momo wheel.
Its 5 years/ 51k miles old.
Absolutely no wear or anything other than perfect.
Old Mar 13, 2008 | 07:46 PM
RuckerPark's Avatar
could you post some picutres of your issue? thanks!
Old Mar 13, 2008 | 08:57 PM
Burklow's Avatar
I have a little part of the leather on the inside of the 3 o' clock position starting to separate at the seams. 27K miles, but besides that, all the wheel really needs is for me to clean it. I sometimes neglect the interior bits.
Old Mar 13, 2008 | 09:15 PM
heavens turbo's Avatar
the only problem i have had is the little plastic piece on the bottom always fell out. i still havent got around to gluing it. as long as the wheel doesn't fall off.
Old Mar 14, 2008 | 01:51 PM
alby988's Avatar
the seam on the bottom fell apart on mine as well. but got it replaced under warranty!
