Spark Plug replacement : Socket doesn't seem to fit
Old Mar 8, 2008 | 01:16 PM
__NiTe__'s Avatar
Hi all,
I'm trying to change out my sparkers for the first time and I'm using the how-to from the how-to section. I got a deep 13/16 from osh, but after dropping the socket down to the spark plug, it seems to hit something and not go all the way down. Any ideas?
Thanks in advance.
Old Mar 8, 2008 | 01:29 PM
bevolucion's Avatar
take it out imidietly. first make sure is a spark plug socket and is perfectly roud outside diameter, second using the correct size, third make sure the socket is long enough, tape the socket to the extension. yeah tape it, when I did my first replacement my socket wan't perfectly roun outside so when I droped it in it got stock in the spark plug hole and when I pulled it it came off the extension. I got it out after like 30min, I bought a new one and taped it to the extension worked nice. if you have all of that meke sure that the rubber that is inside the spark plug socket is farther in so it has plenty of space to grab the spark plug nut ,but enough for the rubber to grab the spark plug(the white long part of it)
Old Jun 9, 2008 | 11:53 AM
Inprogress's Avatar
What should the spark plugs be torqued down to after installing new ones?
Ninj0x
47
May 24, 2018 07:40 PM
SleepySamurai13
Apr 28, 2017 05:04 AM
vx220tony
Outlander Sport
Aug 17, 2016 09:34 PM
Ninj0x
Aug 17, 2005 08:38 PM
laxwax
Lancer Engine Tech
Jan 26, 2004 07:53 PM
