Max HP for stock
Max HP for stock
The main use of my car is spirited daily driving. I do an occasional drag run (ie 2-3 times per year). What I would like to know prior to jumping into bigger turbos is at what HP levels will some of my stock components greatly augment their potential for failure, such as the ACD, Tranny, Engine internals. For example on my other vehicle for drag applications the stock engine internals are good to 500whp, but anything more greatly increases the potential of throwing a rod and the stock tranny is pretty deacent at this level, but would survive longer under stock power levels. Can anyone give me some ballparks for the ACD, tranny and internals without a big explaination that is all depends on how you drive the car.
Thanks!
Thanks!
Thanks!
Thanks!
Detonation kills the motor's if you have a bad tune you can kill a motor at 250hp.
Put all those things aside and look at what people have done on stock components then your looking at 500whp on stock internals. Stock clutch will murder itself in heavy loads seemingly beyond the 450whp mark. Drivetrain with stock components (RS front diff) has seen even 9 second runs...
Now... none of that is guaranteed to last.
On a side note clutch holds torque not whp.
I would say 450/450 is a fun good number because you can get there on a green and race gas/e85/meth with full bolt ons and that would be a fun car to drive.
It looks like the 400-450 range is a pretty safe bet to stick around before I am going to start to break things. So I guess going with an aftermarket turbo setup isnt for me. I am at 340 right now, without cams or a fmic. If I do put in a set of cams and a fmic, what is the cheapest way without using nitrous or meth to pick up 50 ponies from where I am at. Would a green turbo do that (I dont want to overshoot he mark)? But then I am getting into needing all the associated supporting mods (injectors, headstuds, etc..) jacking the price up.
