Launch Control Q
Old Mar 12, 2008 | 11:22 AM
evo86's Avatar
Launch Control Q
Hi,
Whats the best launching rpm you think for an evo?
I personally think its good to launch at 4500rpm.
Old Mar 12, 2008 | 11:26 AM
TeStUdO's Avatar
It depends on your mods and clutch. 4500=burnt clutch and bogged launch. Check the drag racing forum.
Old Mar 12, 2008 | 11:32 AM
filter's Avatar
6000 rpm is what i like.
Old Mar 12, 2008 | 11:33 AM
JordanS4's Avatar
depending on your power levels and clutch no less than 5k, 6k was the sweet spot on a stock clutch and stock turbo, on a turbo kit with an exedy twin it went down because it is too hard to get traction at higher rpms. 4500 is way too low bud.
Old Mar 12, 2008 | 11:41 AM
rush63's Avatar
What has been mentioned above ^^^ plus take your tires into consideration as well.
Old Mar 12, 2008 | 11:42 AM
rcheung's Avatar
Originally Posted by evo86
Hi,
Thats way too low. The last time I tried launching that low my car bogged a bit. My 2 step is set for 6250 and it take off like a rocket.
Old Mar 12, 2008 | 12:08 PM
EvoBroMA's Avatar
stock setup, i was launching at 5700. with my mods now + exedy twin, and the terrible track prep at NED - i launch at 4700.
any higher and i just spin.
Old Mar 12, 2008 | 12:37 PM
philevo's Avatar
6000 for me.... I know guys that launch down low and others that launch at redline, its all on the driver.
Old Mar 12, 2008 | 01:08 PM
jdm_evo8's Avatar
4500 for me
Old Mar 12, 2008 | 01:38 PM
Burklow's Avatar
I think 6000 is ideal. Builds a decent amount of boost off the line.
Old Mar 12, 2008 | 06:53 PM
howmuch4onerib's Avatar
5500 here
Old Mar 12, 2008 | 07:14 PM
Positron's Avatar
I have it setup at 6000 also. Im pushing 328whp on CA mustang dyno. My rims/tires are 18x9+29 265/35/18. It takes off like a roadrunner.
Old Mar 12, 2008 | 07:47 PM
blackevoguy's Avatar
6000 on the street
6500 at the track
Old Mar 12, 2008 | 09:21 PM
TurboRSX04's Avatar
i have mine at 6000 also but at the track i wish i can have it set up at like 6200 or 6500. But as long as u know how to slip the clutch and the tires spin ur transfer case will be fine right? On the street when i launch at 6000 with 8 psi it spins all 4 tires so i should be fine right? i have the exedy twin disc hd btw.
Old Mar 13, 2008 | 12:02 AM
Redline-Z's Avatar
Veteran: Air Force
Mine is at 5500, I hold it untill I see around 10psi and slip it. Stock turbo/stock clutch.
