Stri Boost Gauge Question
Old Mar 12, 2008 | 07:49 PM
jeffbum's Avatar
I just installed my Stri DSD-SLM II boost gauge, I used my factory installed boost line (the one that the MR Gauge pack uses). When i turn the ignition on, and do not start the car the gauge reads around -1 to -2 inHg. I cant figure out why because the car is off. When the car is on and idling it reads -20. Anyone know why?? Thanks in advance.
Old Mar 13, 2008 | 06:09 AM
Chemwarrior's Avatar
Your gauge sounds like it is off. My Stewart Warner did this and had to send it back in order to get a new one.
Old Mar 13, 2008 | 06:38 AM
Burklow's Avatar
I seldom even have -20 in hg at idle. It is usually right at -15 in hg. I'm using an Autometer boost gauge. Definitely sounds like yours is off.
Old Mar 13, 2008 | 07:11 AM
urslo4n8's Avatar
Had the same problem with an Autometer gauge. It wound up being that it was because i installed an LED bulb that was a milimeter too long and it wound up hitting the back of the needle inside.
Old Mar 13, 2008 | 03:39 PM
jeffbum's Avatar
So I called Auto Tech Interiors, since that was the number that is listed on the Stri website. They didn't answer, and have yet to return my call. Tonight I will be sending them an e-mail.
But I did some searching, like I should have done before and read that my vacuum is normal, especially for my altitude. However, I am still curious as to why my gauge still reads a negative mmHg when the engine is with ignition on.
The only thing I can think would cause this is some component causing some sort of vacuum. Hopefully someone will give some insight!
Old Mar 13, 2008 | 06:02 PM
Burklow's Avatar
It shouldn't read any negative when the engine isn't running. The idle for me fluctuates about 5 in hg, so your vacuum may be normal. I just don't trust a gauge that can't reset and zero itself properly when turned off.
ch1215g
Jan 22, 2012 12:44 PM
Johnny Boy
Apr 19, 2010 12:38 AM
tazdevilxxi
Aug 17, 2009 03:44 AM
LetsGo82nd
15
Jun 19, 2009 07:08 AM
racer135
Mar 13, 2008 07:48 AM
