boost leak test = oil leak?
Old Mar 14, 2008 | 04:25 PM
elphalba's Avatar
i finnaly did a boost leak test today and found the tb gasket leaking and of course the pos plastic bov. after i put everything back together i started it and relized i never plugged the maf connector back in . so i shut it off , plugged it in and started it .i then let it idle for a few minutes and shut it off. when i came back a couple of hours ago i found a decent size oil puddle underneath near the turbo . the oil filter and drain plug were tight and oil free .
any chance i could have blew an oil feed/return line doing a boost leak test?
(only went up to 13-15psi)
Old Mar 14, 2008 | 05:05 PM
elphalba's Avatar
guess ill just put it on the lift and hope for the best
Old Mar 14, 2008 | 05:10 PM
Kracka's Avatar
Shouldn't be related. *IF* it somehow did cause the leak then it was inevitable and would have happened very soon anyway.
Old Mar 14, 2008 | 05:26 PM
iturregui's Avatar
When you performed the test, did you block the hose that goes from the valvecover to the intake? Did the car smoke when you started it?
Old Mar 14, 2008 | 05:51 PM
elphalba's Avatar
dont know which hose your talking about, but na didnt block any hose , and no smoke just a a bad idle for about 20 seconds before i relized i forgot the maf sensor
Old Mar 14, 2008 | 06:47 PM
iturregui's Avatar
OK, nevermind
Old Mar 14, 2008 | 07:13 PM
whoang40's Avatar
I didn't know you had to cap that off for a boost leak test. Doesn't the throttle plate close at idle to seal it off the engine?
Old Mar 15, 2008 | 07:11 AM
elphalba's Avatar
i could tell the throttle body gasket was bad by opening and closing the the tb plate and listening for tone changes just like it says on the cobb tuning site , i hope i didnt blow out a the head gasket or a piston ring by letting all that pressure in without the car on. either way well see im going to the shop to check it out now.
thanks for the help
Old Mar 15, 2008 | 11:31 AM
elphalba's Avatar
why do dealerships hire people that cant remember to tighten a drain bolt?
Old Mar 15, 2008 | 11:34 AM
Thegame's Avatar
My local dealership hired people who couldn't remember to tighten lug nuts. That wasn't a fun experience. (not in the evo.)
kaj
Oct 17, 2015 05:51 PM
white4g63
For Sale - Cars For Sale
21
Feb 3, 2012 12:15 PM
stanlsha
Jul 12, 2011 04:04 AM
blackdemon
Aug 24, 2009 04:13 PM
hotshot941
Lancer Troubleshooting
Dec 8, 2008 05:05 PM
