what can i do to fix my guage
Old Mar 18, 2008 | 12:31 PM
Oki Panoki's Avatar
can anyone tell me how i can get inside the guage to fix the face. its twisted and so it reads the wrong boost. im pretty sure thats whats wrong. i also posted a picture of the vac at idle cuz i think that part is correct however, so idk if its reading wrong or twisted. you guys let me know, thanks
Attached Thumbnails what can i do to fix my guage-guage.jpg   what can i do to fix my guage-guage-2.jpg   what can i do to fix my guage-idle.jpg   what can i do to fix my guage-idle-2.jpg
Old Mar 18, 2008 | 12:35 PM
TeStUdO's Avatar
Your vacuum is right at idle. An easy way to tell if the boost is correct is to just run off the wastegate to see if you are running at 11 lb's.
Old Mar 18, 2008 | 12:37 PM
Oki Panoki's Avatar
so your saying i could turn the boost all the way down on my controller and c what the guage reads?
Old Mar 18, 2008 | 12:38 PM
TeStUdO's Avatar
Yeah.
Old Mar 18, 2008 | 12:40 PM
Oki Panoki's Avatar
alright that cant hurt anything i guess
Old Mar 18, 2008 | 12:42 PM
Oki Panoki's Avatar
i guess ill go try
Old Mar 18, 2008 | 12:48 PM
Mr. Evo IX's Avatar
With the car off it should read 0, if it doesnt then I wouldnt suggest trying to fix it, unless you send it to the mfr. Just replace it, it's a autometer gauge. Shouldnt cost too much or be hard to find.
WG presure varies from 11-12lbs.
Old Mar 18, 2008 | 12:52 PM
Oki Panoki's Avatar
okay with it turned all the way down the boost was reading 12psi. but it must really be at 11. so, when i turned it down and back up i counted the clicks and it was 15, if each click is .5psi then that puts me at 18.5-19.5 correct? or dont the clicks represent anything?
and before this the guage looked like it was only reading 17psi at full boost
Old Mar 18, 2008 | 12:58 PM
ROGERV's Avatar
Clicks don't mean anything.
Old Mar 18, 2008 | 01:03 PM
g63tawd's Avatar
Easiest thing to do is with the car off if the gauge reads zero you are good anything else and the gauge is broke and depending on when you bought it you can contact autometer and they will replace or repair it for you I belive there is a sticker on the body of the gauge with the manufacture date or batch code or something to that nature. Autometer is real easy to work with they will help you out.
Old Mar 18, 2008 | 01:05 PM
Oki Panoki's Avatar
alright thanks ill check for the sticker, and give em a call
Old Mar 18, 2008 | 01:07 PM
g63tawd's Avatar
And an after thought, you don't want to open the gauge that would void any warranty there is. How long ago did you buy it?
Old Mar 18, 2008 | 02:02 PM
Oki Panoki's Avatar
it was on the car when i bought it, its used. but it slides out of the holder and it has a little paper sticker on it with numbers. it looks like a price tag sticker in a store so thats probably what u meant
Old Mar 18, 2008 | 03:30 PM
EVO9_IX's Avatar
get a new gauge ehehe
Old Mar 18, 2008 | 03:54 PM
igo4bmx's Avatar
autometer has good customer service
call them and send it in
