Gauge Cluster Swap
Old Mar 20, 2008 | 12:00 PM
EgoBstr's Avatar
Gauge Cluster Swap
Does anyone know if you swap your gauge cluster for a different one if it still reads the correct mileage. My tac is acting goofy (rpms read about 1K under what they should) and I need to swap it. I dont want it to read an incorrect mileage on the odometer.
Old Mar 20, 2008 | 01:19 PM
EgoBstr's Avatar
has anyone done this?
Old Mar 20, 2008 | 01:28 PM
Redline-Z's Avatar
Veteran: Air Force
exactly how do youy know it is under by 1000rpm, have u logged it? Find out how off it is first. I always thought the miles were stored in the ECU, maybe i'm wrong?
Old Mar 20, 2008 | 01:36 PM
gsrboi80's Avatar
95% sure It will read what ever miles are on the cluster and not what was on your car previous
Old Mar 20, 2008 | 01:41 PM
evo_domination's Avatar
^ That's what I've been told. Not certain though.
Old Mar 20, 2008 | 02:14 PM
EgoBstr's Avatar
I know it is about 1K under (and this is a redneck way of knowing) because before I dp would vibrate noticeably at 3800 rpm. Now it is around 2800 rpm. Also at an idle when it was cold it used to idle at about 12-1300 rpm now it hovers around 2-300 rpm when cold and at 0 rpm when warm. All I did was remove the cover and put a new faceplate on it this weekend and not it is all messed up. No clue why or how to fix it.
Old Mar 20, 2008 | 02:23 PM
lilman8403's Avatar
log it and make sure!
Old Mar 20, 2008 | 02:28 PM
evo8426's Avatar
you could get it calibrated possibly
Old Mar 20, 2008 | 02:30 PM
EgoBstr's Avatar
Good point. Because the revs seem to respond properly, but they are off by that 1000K+- rpm.
Old Mar 20, 2008 | 02:42 PM
TouringBubble's Avatar
did you happen to remove the RPM needle in the process?
Old Mar 21, 2008 | 12:31 AM
Jameson_IXMR's Avatar
^ good point. I have never taken mine apart but I would imagine you can adjust your needle or the gauge somehow. Most indicators for every application (boats/airoplanes I know for sure) have a small adjustment screw on the reverse side for this type of calibration. It should only adjust the needle position though.
Old Mar 22, 2008 | 08:56 AM
halcyon0's Avatar
You may want to try the PLX gauge system that plugs directly into your OBD port and takes readings from the ECU. It's super nice.
Old Mar 22, 2008 | 04:20 PM
Sti THIS's Avatar
the ECU stores all information, such as milage. Thats why its funny when people on this site by "lower milage" gauge clusters to increase their cars value. I bet they are pissed when they see it hasnt changes and they just lost 100 bucks
Old Mar 22, 2008 | 04:41 PM
LancerEVA06's Avatar
Mileage and cluster layout (so the motors move to 1000 RPM, Full Fuel, Hot temp, etc, correctly) is stored on a 8 pin IC chip on the back of the cluster. Nothing is stored in the ECU.
Old Apr 5, 2018 | 08:29 AM
S.Brewer's Avatar
FCOTM Winner
i was thinking this too too because I bought a used cluster for a TSX I had and swapped it trying to diognose a problem and realized the cluster read the other cars mileage and I was mad cause it was like 50k off lol. Anyways, upon research I discovered that most of not all cars store data in the cluster but the ECU.
