Spark plugs Replaces at 13,000 miles
Old Mar 26, 2008 | 01:08 PM
vegasevo9's Avatar
I have been reading a thread about spark plugs. Most people dont change it for awhile. I only have 13,000 miles and they need to be replaced already. I had a boost leak and I was driving the car for maybe 3000 miles. Is this the reason why?
Old Mar 26, 2008 | 01:12 PM
Burklow's Avatar
How do you know they need to be replaced? Lot of carbon build up? Stock plugs should last a long time. They're expensive as well so you hope you don't replace them every other weekend unless you switch to copper or something.
Old Mar 26, 2008 | 01:19 PM
vegasevo9's Avatar
I checked them last night and they were really pointy. Not flat anymore. I was thinking the same that they would last long since they are iridiums..
Old Mar 26, 2008 | 03:03 PM
dsmfan95's Avatar
I thought the electrodes on iridiums were pointy to start with?
Old Mar 26, 2008 | 05:34 PM
sleepyS14's Avatar
NGK's all the way. don't use BOSCH..those were only meant to be in German cars.
Old Mar 26, 2008 | 06:01 PM
DanJ's Avatar
pointy? i thought you tell if spark plugs need replacing due to the color and **** off the plug not the electorde tip condition?
Old Mar 26, 2008 | 06:37 PM
Evo8luva's Avatar
I use ngk coppers and they are dead after 6-7k, whatever, cheap and easy to replace
Old Mar 26, 2008 | 06:39 PM
Draven83's Avatar
i replace mine every oil change just to be safe. i dont know about you guys but i love my car so spending like $20 extra for plugs on a oil change i am glad to do. Go with NGK BPR8ES
psphinx81's Avatar
i change my plugs every oil change, which is about 700 miles in my case
Old Mar 26, 2008 | 06:43 PM
sblvro's Avatar
I replace mine every tank of gas, are you kidding! the spark plugs should last you a long time!
Old Mar 26, 2008 | 06:50 PM
Mr. Evo IX's Avatar
Dont get confused with all the Evo VIII people posting. The IX plugs cost $50.00 a set for OEM, lots more for 1 step colder. You want them to last as long as possible.
The guys that are changing them all the time are running probably running a copper plug that costs a few dollars. Yes a boost leak will cause your car to run rich under boost and could have fouled your plugs. These cars run pig rich to begin with and a boost leak will just make it worse.
Be careful, not many plugs will fit in a IX and most people run the OEM plugs, you can get them on sparkplugs.com by looking up the part number (owners manual).
Old Mar 26, 2008 | 07:35 PM
vegasevo9's Avatar
Thanks. I will be picking som up at the dealership tomorow.
Old Mar 26, 2008 | 08:42 PM
jmartinez1170's Avatar
Just change your plugs every oil change. For something that only cost a 1.75 a plug why would you wait? I treat oil changes and plugs changes like they where a fill up at my local shell. $28 for a oil change and plugs.
Old Mar 26, 2008 | 08:44 PM
evo637's Avatar
I replace mine every 15k but I do track my car...you can probably get away with replacing it every 30k if you only DD your car
Old Jun 23, 2008 | 09:08 AM
IAmADirtDude's Avatar
anyone know if im running really rich if a fouled plug could cause a major power loss?
i feel like i've lost about 20 whp i have no boost leaks but i know the car runs quite rich from my dyno sheet. i feel the loss mainly in the torque but i know it's just plain lost power. clutch is good im coming up on 10k miles but my tune has been on for about 6k miles
