How to install shifter bushings?
Old Mar 28, 2008 | 04:49 PM
subrwho's Avatar
Hi guys, I just got my shifter bushing kit from Bushur. I was looking and couldn't find a how to on this. anyone know where I can find a how to or anything? thanks!
Old Mar 28, 2008 | 04:53 PM
bmguser's Avatar
search mang!.... howtos and links are all over the place if you even remotely attempt to search for the answer! anyhow go to ....evomoto.com
Old Mar 28, 2008 | 07:42 PM
Burklow's Avatar
+1
But Basically:
- Remove Battery (disconnect it first obviously) and tray with 12MM and 10MM sockets
- Locate stock bushings. They're a little north of the battery tray edge facing the firewall.
- Remove and save both cotter pins (Use needle nose pliers) and washers from stock bushings. If you drop them, they are a pain because they can get caught in the under tray.
- Take cable and bushing off of tranny linkage pins. Should slide right off.
- To remove stock bushings, take a screw driver and place it in the hole in the middle of the bushing and leverage it to turn the little rubber bushing sideways. It is easy to push out from that point.
- IMPORTANT. First, lightly grease the bushings to prevent seizing. Second, install the new Buschur bushings onto the pins and THEN but the cable on the bushing. Not on the cable and then the pin. I could never make it fit that way.
- Install E clips onto bushings by pushing hard or squeezing with a large wrench.
- Reinstall washers and cotter pins.
- Reinstall battery and tray. Reconnect battery.
PM me for specifics. I did this install a few days ago so it is still fresh in my mind, but it is hard explaining in text.
Gavinrowe
Evo X How Tos / Installations
Jul 3, 2015 01:03 PM
wilsonevo8
Mar 5, 2013 10:27 AM
evosweens1
Jan 12, 2012 10:01 AM
GTS08
Apr 9, 2009 09:02 AM
bolsen
Jun 2, 2008 06:13 PM
