Noise from right rear please help!!!!
Old Mar 29, 2008 | 08:27 AM
Happy29's Avatar
I swapped out my snow rims and tires back to stock now my right rear is making a weird squeak when I brake. I know that the Brembos squeak but its not that kind of a squeak. Its more like a squeak only on a certain part of the rotor (if that makes sense) I took it to ntb this morning and they said I had glazing on my rotors from them overheating and thats what was doing it but I didnt have this problem with the snow rims and tires on. Please help just to give me piece of mind.
Old Mar 29, 2008 | 08:52 AM
evascst's Avatar
have you taken the rims off and checked it yourself? how did everything look?
Old Mar 29, 2008 | 09:01 AM
Honto's Avatar
Make sure the shield on the back side of the rotor isn't rubbing against it.
Old Mar 29, 2008 | 09:03 AM
Happy29's Avatar
You know I thought of that while I was driving, but why would that happen just from swapping the rims? I am baffeld.
Old Mar 29, 2008 | 09:16 AM
evozakk's Avatar
If you banged the shield when you put the wheel back on? Not to get you noid but my wheel bearing shredded and it started off as a squeak lol.
Old Mar 29, 2008 | 10:22 AM
Lonnie@LMS's Avatar
Yeah, this is hard to diagnose without being able to hear it. It could be the dust shield rubbing, a glazed rotor, brake pad wear indicator, stuck caliper, hanging e-brake cable, debris wedged in there somewhere, wheel bearing. Pretty good list to go through. Check the easy stuff first obviously, good luck!
Old Mar 29, 2008 | 11:02 AM
Happy29's Avatar
Thanks man first off. I dont know dude I am completely clueless as to what it is I just dont understand why this would just start happening right when I change my rims. Unless since I rotated them and now have the 20 weights in the fron and the 10s in the back but I cant see that being a problem.
