Greddy turbo timer
Old Mar 29, 2008 | 04:10 PM
evobullet's Avatar
Question Greddy turbo timer
When i bought my evo it already had a timer in it and it doesn't work. Is there a way to reset it or like start over so it is all original settings? because i cant figure out how to make the timer work it just shuts off when i turn the car off. Does any one know what things i should try to get it to work?
Old Mar 29, 2008 | 04:14 PM
eponti's Avatar
Go to greddy.com and you can download the instructions.Its under tech support sections.
Old Mar 29, 2008 | 04:19 PM
Mr. PSSsSt's Avatar
FCOTM Winner
^ +1
Old Mar 29, 2008 | 04:36 PM
evobullet's Avatar
Originally Posted by Mr. PSSsSt
^ +1
Already did that it didnt do me **** it doesnt say nothing about resetting it or anything like that and the instructions are way hard follow too.
Old Mar 29, 2008 | 10:27 PM
EvolNinja's Avatar
Check the wiring. The owner before you don't know how to install it. I would guessed
Old Mar 30, 2008 | 02:54 AM
SYNRGY's Avatar
there is a small black switch on back. try both settings. im not 100% sure but i think it has to do with which acc. wire to use
Old Mar 30, 2008 | 03:18 AM
W_evo8's Avatar
take the steering wheel column plastic peice off and see if its wired into the ignition.
Old Mar 30, 2008 | 08:50 AM
evobullet's Avatar
The wiring in the car makes me sick i dont even want to toch it the kid ****ed it up so bad.
If i flip the switch it wont turn on on the other setting.
I will look under there and see what is up.
Old Mar 30, 2008 | 08:54 AM
W_evo8's Avatar
if its hacked really bad, solder the factory wiring back together and purchace a TT harness if you don't have one it will save so much headache.
Heres a write up I made:
https://www.evolutionm.net/forums/sh...d.php?t=292220
Old Mar 30, 2008 | 12:19 PM
eponti's Avatar
^+1 coz with the TT harness its pretty much plug and play.
Old Mar 30, 2008 | 01:29 PM
evobullet's Avatar
I guess it wouldn't hurt to start over but i dont know if i want to deal with that head ache and i read somewhere that if you have to jump the car cause the battery goes dead you are suppose to disconnect the TT or it my fry it so maybe that is what happened cause i had to jump it the other day
Old Mar 30, 2008 | 03:08 PM
SYNRGY's Avatar
did it just stop working?
just start all over and do it the right way, you don't want to bandaid a already hacked setup. its a good small step to learning to modify your car. do it right the first time around, even if it takes you a couple hours.
Old Mar 30, 2008 | 06:21 PM
evobullet's Avatar
ya it did just stop working and if it is fried i might just remove the thing and fix everything and not put a new one in i would rather spend the money on new gauges and stuff rather than a TT.
Old Mar 30, 2008 | 07:11 PM
AznEvoIX's Avatar
Ouch. Previous owner didnt take care of it I wonder?
Old Mar 31, 2008 | 12:43 AM
SYNRGY's Avatar
well since you already have one, might as well fix it. and you end up knowing how to hook one up. that way next time you want to install one, it won't end up like the hack job the previous owner did. your work quality reflects on the car. or atleast that's how I see it.
