Lower RPM after putting aftermarket BOV!!
Old Apr 1, 2008 | 09:49 PM
alexyim's Avatar
Whatsup everyone! As the topic says, my evo's rpm has been dropped after i change to an aftermarket BOV. Questions are 1. Is this an normal problem for changing BOV? 2. Can i fix this by refreshing my ECU?
Thanks for looking and i appreiate the opinion!!
Old Apr 1, 2008 | 10:01 PM
chaotichoax's Avatar
you need to search but I'm in a good mood
if the valve is VTA then that is your issue
you could "band-aid" this issue with an ecu reflash however disconnecting your battery won't do much good
do yourself a favor...if you are running a stock or stocklike turbo get yours an evo ix diverter valve
and read this https://www.evolutionm.net/forums/sh...d.php?t=330085
closed...
