Air temperature from turbo to IC question
Old Apr 4, 2008 | 04:44 PM
gunhaha's Avatar
How hot does the LICP normally gets up to?
I installed my Nisei LICP and there is this rubber hose hanging down (going down then up) there that sits on top of the LICP. I'm not sure what that is (maybe AC or oil hose). I can put it in fron or back of the LICP but it still kind of sit on it (contact).
Will the LICP get so hot to damage that hose?
Thanks,
gunhaha
Old Apr 4, 2008 | 06:09 PM
Lonnie@LMS's Avatar
No, it will be fine.
Old Apr 4, 2008 | 06:14 PM
spdracerut's Avatar
The air coming out of the turbo can be 300F+ degrees. So the LICP can get pretty warm....
Old Apr 4, 2008 | 09:17 PM
gunhaha's Avatar
Anyone else have this issue with the hose touching the LICP?
Old Apr 4, 2008 | 09:34 PM
Lonnie@LMS's Avatar
The outlet of the turbo has a rubber hose connected to it for the boost signal to the boost controller dosn't it?? So I believe that something else rubber touching it would not be affected by simple logic.
Old Apr 4, 2008 | 10:23 PM
gunhaha's Avatar
Good point. I should have thought of that.
Thanks guys.
