Revers lights help.
Old Apr 5, 2008 | 08:55 PM
rashoodi's Avatar
Revers lights help.
Hey there guys. A little help needed. I was trying to install a rearview camera and my tail lights went out. The thing is i tried to do it the lazy way, by cutting into the reverse lights wiring and i blew a fuse. iI replaced the fuse, got my rear lights back working although the reverse lights are still not working! I checked all the other fuses and everythings fine. I hope i didnt blow the reverse switch. If i could get some help on this would be great! Also, my SRS light is on now. How to i reset this? Thanks alot guys!
Old Apr 5, 2008 | 10:35 PM
ImJoey's Avatar
Insert a wick into your gas tank, light it, and run like hell,
No but seriously you probably shorted something.Good luck with that.As far as the SRS it could be one of many things. If I had answers Id give them really, otherwise I tell you to use the search feature.I find my answers there mostly.
Old Apr 5, 2008 | 11:49 PM
darkside2's Avatar
I would run a scanner and get the code and maybe check the bulbs. Always take the cheapest route first.
Old Apr 6, 2008 | 04:48 AM
CanMan's Avatar
To reset the SRS light, try disconnecting the battery for a bit. That may reset it, unless your EVO is like mine, and you have a bad airbag module.
