AEM Wideband Sensor
Old Apr 6, 2008 | 07:42 AM
SuperchargedGTZ's Avatar
AEM Wideband Sensor
I think my sensor is starting to go bad, because it is starting to read "funky". it is reading now 2 higher than typical, and sometimes at idle it reads steady at 14.9.
where can i buy one of these? I did some research and i am pretty sure that the sensor AEM uses is a bosch part number 30-2001. Is this correct?
Old Apr 6, 2008 | 07:45 AM
CanMan's Avatar
I would imagine that if you emailed AEM they would tell you what sensor you need. I would hate to see you get the wrong one.
Old Apr 6, 2008 | 07:54 AM
otter's Avatar
EvoM Administrator
You'll have to get it from AEM. AEM puts a laser-etched resistor onto their harness that's specific to that wideband. Soldering another wideband to it could cause inaccuracy.
Originally Posted by AEM
Q: Can I use a different UEGO sensor than the one supplied?
A: No. The supplied Bosch sensor is calibrated specifically for AEM Wideband UEGO controllers.
Q: Can I change the UEGO sensor’s connector?
A: No. There is a laser-etched, calibrated resistor in the sensor’s connector body. This resistor is specifically created for the exact sensor that it is attached to. Modifying this will invalidate the sensor’s output.
MurtazaDSM
Feb 16, 2017 05:42 PM
dspize
Jul 26, 2014 05:24 PM
jameswwt
Aug 10, 2012 11:38 AM
erikm-x
10
Apr 19, 2012 09:47 PM
My03evo
Feb 3, 2011 08:23 AM
