Oil change
Old Apr 14, 2008 | 10:53 AM
evo9mr0006's Avatar
Oil change
Is it worth it to have a dealer change all my fluids. Ill do the oil change but i have never did a transmission fluid change or acd change. Should i just take it to the dealer?
Side questions:
How much will it be?
When should you change it (how many miles)?
any help is appreciated.
Old Apr 14, 2008 | 10:57 AM
Burklow's Avatar
Side questions:
It cost me $300 to have dealer do tranny, TC, and rear diff. The fluids are expensive as it is, so is it worth it to you? I'm doing my next one in 15k on my own.
30k regular usage.
15k severe usage.
Don't forget the big 60K mileage service.
Old Apr 14, 2008 | 10:59 AM
evo9mr0006's Avatar
Im at 14,000 miles and have only done oil changes. I drive my car like a baby also. So you think im okay for another 15,000 miles before i touch any other fluids?
Old Apr 14, 2008 | 11:03 AM
dpacific's Avatar
What is the big 60k millage service. Not sure if mine had it done and i hate paying dealers to do work I can clearly do myself.
Old Apr 14, 2008 | 11:11 AM
596736's Avatar
I believe most members on here do it at 15k then at 30k. I had everything done at 15k because I upgraded my clutch. I'm at 31k now and plan changing fluids myself this weekend. Its pretty easy and there are great how toe on here. Also use the oem diaqueen fluids
Old Apr 14, 2008 | 12:20 PM
JDMCT9MR's Avatar
+1 on the oem fluids.
Old Apr 14, 2008 | 12:24 PM
lemmonhead's Avatar
i change my own motor oil, but as far as the differential, lsd, transfer case oil, I let the dealership do it because in the tech manual you need their special tool to pump out all the pressure fluid completely and to bleed the acd.
sure accessing the drain and fill hole is easy but i rather have it done completely not %75.
Old Apr 14, 2008 | 12:56 PM
grillpt's Avatar
Timing Belt & Water Pump along with all the pulleys and balance belt. Parts are around $350. You should know if this has been done or not.
Old Apr 14, 2008 | 02:39 PM
DRAGHICI's Avatar
i went to the dealer for my first oil change, they forgot to install the o-ring on the drain plug and I had leaks on my driveway.
no more dealer oil changes 4 me
Old Apr 14, 2008 | 02:43 PM
JJLANCER02's Avatar
for a trans,transfer,rear it only 65 for each pop so 195 bucks at the dealer
Old Apr 14, 2008 | 02:54 PM
Ralliart03's Avatar
Its always best to do it yourself. You choose the fluids of your liking, and you make sure its done properly. When bringing it to a dealer you take the risk of someone forgetting a ring or not fully letting the fluids drain. Sometimes they don't even top it off.
