Trans fluid change
Old Apr 16, 2008 | 09:05 AM
DSM GSR04's Avatar
Redline is used by Shep, who builds all the drivetrains for the most known high HP evos.
Also If you dont have the gigantic socket for the drain bolt in your socket set you are screwed. Good luck with a crecent wrench.
Old Apr 16, 2008 | 09:13 AM
xsolowx's Avatar
what is the recommended interval on these...no manual in my used evo...
Old Apr 16, 2008 | 09:16 AM
newbieEVO8's Avatar
OEM fuilds.
Cant go wrong there.
Old Apr 16, 2008 | 09:21 AM
SME's Avatar
SME
Originally Posted by Brad@MellonTuning
OEM fuilds.
Agreed
Old Apr 16, 2008 | 10:11 AM
lemmonhead's Avatar
your thinking of YAW control, yes USA dont have that in the pre evo X. But we do have ACD which is Active Center Differential.
Originally Posted by gsrboi80
^ No you need a special tool if you want to change the ACD Fluid which you dont have. Basically it keeps the pump running to drain out the old while adding the new.
tc, trans, and rear diff changed normally. As easy as loosening any bolt
Old Apr 16, 2008 | 11:56 AM
red evo8's Avatar
diy redline mt90 and diaqueen ftw!
Old Apr 16, 2008 | 06:50 PM
SpyderTB's Avatar
Just change the trans fluid today it was a lot easier than i thought took all of well....an hour after i had to go buy an 24mm wrench due to the lack of space cuz my 24mm in my 3/4 set sure wouldnt fit
Old Apr 16, 2008 | 07:14 PM
Oil Doc's Avatar
Originally Posted by kingman4
contact oildoc for teh amsoil hookup. He ships FAST and cheap.
I recently put amsoil in my tranny and it made a huge difference. much smoother now.
Thanks for the Kudo's...
I have been switching quite a few over to AMSOIL fro Redline the last few months... Been receiving very good reviews as far as smoother shifting immediately, especially when cold..
Doc
Old Apr 17, 2008 | 05:58 AM
kingman4's Avatar
I used vice grips...
Old Apr 17, 2008 | 06:09 AM
Chemwarrior's Avatar
I recommend using OEM fluids for your transfer cases and using Redline MT90 for your transmission.
I can't believe you don't have a socket large enough to undo your transmission fluid bolt. I guess I just accumulated a lot of tools through the years.
Old Apr 17, 2008 | 09:20 AM
kingman4's Avatar
i can't think of very many uses for a 24mm socket/ wrench
Old Apr 17, 2008 | 10:07 AM
GONMAD's Avatar
I can think of 1 use for 24mm socket. It is enough of a reason to have one.
Old Apr 17, 2008 | 10:10 AM
My socket set included the 24mm socket so I guess I bought the right one. You got to love Craftsman.
Old Apr 17, 2008 | 10:14 AM
pog0's Avatar
I use OEM in mine and I think a few people with built trans use the Super Diaqueen in their transmissions, which is the stock 6 speed fluid.
I would much rather have a socket over the hex key.
Old Apr 17, 2008 | 10:32 AM
W0459732's Avatar
im doin it this weekend.
