Trans fluid change
What's hesitating me from buying Redline or Royal Purple or even GM-Synchromesh is something about ...its good at first for like 2k miles and then it gets bad.
How is your experience?
Do you recommend getting your transfer case fluid changed at the same time as your trans fluild?
It is not necessary to change your differentials as often as your transmission fluid. I would definitely recommend using OEM (LSD Diaqueen) for the differentials, but you will hear many different opinions on what to use for your tranny fluid. I have used Royal Purple, LeadingEdge, and currently just put in Redline MT90 with a splash of Heavyshock. I would recommend Redline MT90 out of those three choices. You won't hear any bad things about Redline. I would suggest doing a search and see all the positive things said about it, but in the end it is your choice.
Isn't MT90 thicker?
Seems pretty normal to me, but do it yourself if you are in a pinch.
Sean
06RS
Sep 25, 2007 07:37 AM
