Death Whine
Old Apr 17, 2008 | 10:37 PM
john151's Avatar
Death Whine
So the other day I was driving and I found an open patch of road in Gainesville with no cops around (trust me a very rare occurence) and decided to open her up. At around 5k in 3rd gear I felt something give and the car stopped accelerating well, as if the clutch wasn't grabbing. I tried to get her to pull a few more times but she just stopped pulling well at about 5-6k rpm.
Now whenever I get the car going over 30 a whining noise starts coming from what sounds like the tranny. After a quick search it seems that I have got the dreaded transfer case "Death Whine".
At this point in my Evo ownership experience I am about to drive it off a cliff laughing because I just spent 2200 to fix a freak enging malfunction about a month ago. (A spark plug somehow came loose, popped up out the top end taking the threading with it and tore my top end a new one, while I was going about 5mph).
Point is I am a broke a$$ college student who had to take out 2 credit cards to fix the last problem. I am just looking for any ounce of good news from any of you guys.
I am asking to see if anyone has heard of just plugging along with the Death Whine. I need to get around, and I have been babying the hell out of it (not going over 60pmh and accelerating in a snail like manner). Has the damage been done? Can I go on like this indefinetly? Is continuing to drive it gonna mess up anything else?? Should I stop IMMEDIATELY and fix this?
You thoughts....
Old Apr 17, 2008 | 10:44 PM
tripperfx3's Avatar
You say the car stopped accelerating? What happened after this? Would it only go up to 30 MPH or what? Does the car accelerate like normal now, but just with the whine? It sounds like either a trans. problem or T case problem.
Old Apr 18, 2008 | 12:03 AM
red evo8's Avatar
some people actually go a year or more with it i think i possibly got the wine today as well i might try to finish her off this wknd at the 8th mile lol im in college as well.
Old Apr 18, 2008 | 12:09 AM
RoadSpike's Avatar
Does it sound like this?
http://www.youtube.com/watch?v=TXbisxnAW-s
Old Apr 18, 2008 | 12:13 AM
xLaNcErEvOx's Avatar
mine whines just like that video.... i recently drove it 200 miles away for a roadtrip and it was HORRIBLE. I want to gouge my ears out!!! Too broke to fix it right now.
Old Apr 18, 2008 | 12:15 AM
RoadSpike's Avatar
Just as a FYI the guy in that video has apparently been driving around with that problem for over a year
I don't recommend that.. but if you do have the whine change your fluids immediately to rid the case of debris which may further damage it.
Old Apr 18, 2008 | 07:00 AM
Ev0cRaZy's Avatar
When they do go, do they lock up and lock all the wheels up or what?
Old Apr 18, 2008 | 07:04 AM
evoracingstar's Avatar
o mine did this one scared the crapt at me i forgot wat he told me happen like something broke got stuck between the gears and locked it up. sucks man transmission and t-cases r maddd $$$ lol that was on one of my old evos. got rid of that thing!
Old Apr 18, 2008 | 07:12 AM
Ambiguous's Avatar
John151 how many miles are on your car, wat mods and wat year?
Old Apr 18, 2008 | 07:17 AM
KevinD's Avatar
You thoughts....
you can generally drive them around for a while, but it gets louder and louder as more ring and pinion gear teeth get chips in them. they will eventually seize up as well leaving you stranded on the side of the road.
also, why was your bill 2200 for a spark plug that popped out? i actually had the same thing happen to my car... ripped all the threads out of it (spark plug was backing out slowly because i obviously didn't torque it down enough). i simply went to autozone, got a tap with a threaded insert, tapped it out, put the insert in, and walla! works like new, cost me maybe 20 bucks (plus a new spark plug,coil, and wire, which was maybe 100). i spent a great deal of time cleaning the cylinder out for metal pieces from rethreading it so it took the better part of an evening.
Old Apr 18, 2008 | 07:23 AM
Evo8luva's Avatar
I had a t case lock up on one of my 450whp dsm's when the rear seal failed at the 1000' at gld, put me into the wall. I took it apart and the transfer gear had welded itself together; I'm pretty sure it was a rear seal failure. I think eventually that is one of 2 possible outcomes, the other being the transfer gear will break making your car fwd and it will kill your center lsd real quick or the front diff will blow up most likely destroying everything. I would not reccomend driving the car, having a tcase lock up is NOT fun.
Old Apr 18, 2008 | 09:39 AM
DSM GSR04's Avatar
First off, you need to fond out what is whining, the only way to that is to get the car on a lift, and have a mehcanic use the stethescpoe to listen under the car while its in gear and the wheels are moving.
Then you can tell where the whine is coming from.
It could be just a wheel bearing or it could be your T-Case.
BTW, my T-case has been whining for over a year. It is absolutley dreadful.
Old Apr 18, 2008 | 10:35 AM
Ev0cRaZy's Avatar
I had an issue last week of my ACD fluid leaking into my Tcase and I didnt know till It started whining like crazy and I popped the fill plug off and tons of milky fluid came out. Its not my DD and I already have another Tcase on its way, i was just wondering what would happen if it did give out.
Old Apr 19, 2008 | 10:16 AM
Ambiguous's Avatar
Is there any difference in t-cases, mainly durabillity, between the 03-04 evos and 05-06 evos with acd?
Old Apr 19, 2008 | 10:30 AM
importjake00's Avatar
how much are t cases?
