Where to weld the WB O2 bung?
Old Apr 21, 2008 | 06:05 AM
EvolNinja's Avatar
I've done some research but some weld theirs vertically about 2 inches away from the Cat and some weld it at 3 O'clock. I just want your confirmation that it's ok to weld it vertically about 2 to 3" away from the Cat on the DP. Thanks
Old Apr 21, 2008 | 06:33 AM
madmax199's Avatar
You need to have it in the 3 O'clock position so condensation doesn't ruin the sensor and make sure it's before the cat as far upstream as you can.
Old Apr 21, 2008 | 06:37 AM
phat_bastage's Avatar
Stickied in the how-to section w/ Pictures
TeStUdO's Avatar
2-3" from the cat on the dp is the perfect place for it. I welded mine at 12 o'clock. As long as you dont weld it lower than a 45 degree angle, you should be fine.
Old Apr 21, 2008 | 06:38 AM
jmelocik's Avatar
If my understanding is correct it needs to be at least 18" from the turbo and ideally no closer then 6" to the cat. Yes it can be anywhere from the 9 oclock to the 3 oclock position, do not mount it angled down because as previously stated, moisture will collect on it and ruin the sensor. Hope this helps.
Josh
https://www.evolutionm.net/forums/sh...ad.php?t=84914
Old Apr 21, 2008 | 10:00 AM
EvolNinja's Avatar
Ok, some say 3 O'clock angle and others says Vertical which is on the top of the pipe like the one on the link provided. I'm thinking of doing that way too since there's more room for the O2 sensor. Any disagreement?
Old Apr 21, 2008 | 10:31 AM
Chemwarrior's Avatar
I have mine at the 3 o'clock position with no adverse effects.
Old Apr 21, 2008 | 10:35 AM
travman's Avatar
Mine is at the 12 o clock position - if you get a flashlight and look down between the firewall and intake manifold you can see the dp, that is where mine is mounted. Ran the wire up the firewall and into the car through the hole by the glovebox.
Old Apr 21, 2008 | 10:46 AM
EvolNinja's Avatar
Ok, at 12 O'Clock it is that I'm going to mount my O2 sensor. Thanks for your help guys. Oh by the way, There's only 4 wires on the O2 sensor. Battery and Ground. The other two are for the Serial Output and Data Output. Do you guys get an RS232 connector and tap that two wire and connect to the computer to read data off from the O2 sensor?
Old Apr 21, 2008 | 10:59 AM
EvoBroMA's Avatar
12 o clock is fine.
Bosch recommends >=10*.
i mounted mine at -15*. condensation may shorten my sensor life.
evostang
Evo X How Tos / Installations
33
May 16, 2019 03:22 PM
Jamesm331
Nov 19, 2013 12:11 PM
Ludikraut
55
Mar 10, 2011 11:47 AM
bbbwrx
38
Jan 11, 2009 08:58 PM
bbbwrx
Jul 30, 2006 07:57 PM
