Dim gauges
Old Apr 29, 2008 | 08:07 PM
Inflation's Avatar
Dim gauges
On my 03 evo 8 the dash gaues are so dim I can't see them when night time drving. I checked the switch for intensity by my left knee but that helped with the interior ( Radio, AC area etc) But it did help with the little orange mileage box in the gauge cluster but not the gauges themselves. So I replaced the fuses sill no luck. Any idea?
Old Apr 29, 2008 | 09:06 PM
Vigman's Avatar
Are that OEM dash gauges?
I think they come with regular incandescent lamp...why dont your try to disconnect OEM wire and connect light wire directly on +12V? You will be able to check first if it due to wiring or lamp...
1-If it's wiring: rewire from another source.
2-If it's lamp problem, take your shot to replace lamps with Leds...
Hope this could help!
Cheers
Old Apr 29, 2008 | 10:28 PM
Inflation's Avatar
Yes they are the OEM ones.
So I'm going to need to remove the gauges to get this all done?
Old Apr 30, 2008 | 05:19 AM
Vigman's Avatar
yep but no worry it's easy!
Where do you have them: Up in the radio place or down?
It's located usually down...2 screws on the top side of relocation kit.
Old Apr 30, 2008 | 11:49 AM
Inflation's Avatar
I'm talking about the speed, rpm, fuel, h-c, and Lancer gauges
Old Apr 30, 2008 | 05:24 PM
TheShortBus's Avatar
mine are really dim on my oz as well :/
Old Apr 30, 2008 | 06:09 PM
Vigman's Avatar
Oh sorry man!!!! in this case, I never take it off, and I think it will take a while!!!
Same procedure anyway but don't know where tricks are for disassembly...
Good luck,
Cheers.
michiganevox
Evo X How Tos / Installations
Aug 23, 2010 02:06 PM
Need4Spd
Jul 18, 2009 10:56 PM
flashy
Jan 29, 2007 09:14 AM
superscout03
Aug 23, 2006 11:07 PM
mikenjulie
Dec 28, 2005 12:16 PM
