Help Me Remove Steering Links!
Old May 11, 2008 | 03:14 PM
bboy_RES's Avatar
i'm stuck on my clutch install. im trying to remove the steering links so i can drop the subframe in order to get more room to remove the tranny. i cant seem to knock the steering links off of the knuckles. my buddy came over to try to help me but he had no luck either. i tried hitting the top of the tie rod bolt with a rubber dead blow hammer and that didnt work. i tried hammering a ball joint tool in between the tie rod and knuckle, but that didnt work either. someone told me to try heating the knuckle up with a torch to expand the metal. any body have any other ideas? i can make videos of my unsuccessful attempts. here are pics of what im trying to remove.
Old May 11, 2008 | 03:47 PM
Exciting News's Avatar
When you say ball joint tool are you referring to a separator fork? I think the only thing you'll eventually do with that is shred the dust cover. You could try a pitman arm puller/tie rod end puller. If you have an autozone nearby you can rent from them.
http://www.autozone.com/in_our_store...ie_rod_end.htm
::Edit:: I'd also like to add I've never done a clutch on this car. Pulling and repressing a ball joint is a PITA. Could you just remove the control arm altogether?
Old May 11, 2008 | 04:00 PM
skold's Avatar
dont drop the frame there is no need to, youll get wha ti had happen frame bolts spin freely
Old May 11, 2008 | 05:28 PM
cfdfireman1's Avatar
Hit the knuckle from the rear with a "real hammer" a few times the tierod end will fall right out.
Old May 11, 2008 | 05:41 PM
monckee's Avatar
un-necessary. I just completed a clutch install without dropping the subframe. Easier to take out the studs on the driver side mount.
Old May 11, 2008 | 07:22 PM
bboy_RES's Avatar
took me 10 seconds to remove the tie rod with the tie rod puller! thanks for the advice man!
Old May 11, 2008 | 08:14 PM
chaotichoax's Avatar
fyi for all the subframe advise:
a mr tranny isn't the same as a five speed in terms of a clutch install
bboy_RES
For Sale - Part Outs
23
Apr 15, 2012 03:02 PM
bboy_RES
For Sale - Cars For Sale
Jan 9, 2012 03:43 PM
bboy_RES
Mar 7, 2010 08:39 PM
bboy_RES
Oct 25, 2009 03:59 PM
bboy_RES
May 13, 2008 09:16 PM
