Code Reader "No Link"
Old May 12, 2008 | 10:24 AM
yikez's Avatar
I recently had a problem with my evo ix. Thread : https://www.evolutionm.net/forums/sh...d.php?t=341816
During that process i got a check engine light. Dealer tried using their MUT to read the code but got no link. It's strange because their MUT was able to read the codes when i used to get check engine lights in the past.
I tried my code reader (which worked always before), but i get "NO LINK".
Car runs fine and everything is working 100%. I just can't get a code for that check engine. It keeps on saying "NO LINK" when i press read.
Has my ecu gone bad? Has this happened to anyone before? I searched and couldn't find anything
Old May 12, 2008 | 10:43 AM
PHDoc19's Avatar
Could be some broken pins on the OBD II plug...
Old May 12, 2008 | 12:57 PM
EVIL MR's Avatar
Do you have a small battery?
Old May 12, 2008 | 01:39 PM
yikez's Avatar
It could be the pins on the obdII port. However, i haven't touched the port for the check engine light to appear..only after i got the check engine, i tried to read the code and got NO LINK. I'll check the pins though just to be safe.
I have a stock battery
What else could it be?
EVIL MR's Avatar
fuse.
Old May 12, 2008 | 01:46 PM
yikez's Avatar
That could be it .. i'll check that tomorrow and get back to you!
I hope it's something simple like that ..
Old May 14, 2008 | 05:11 AM
yikez's Avatar
bump ...
can anyone help me out here..
Old May 14, 2008 | 10:33 AM
yikez's Avatar
bump
has anyone heard of this before?
Old May 15, 2008 | 07:41 AM
yikez's Avatar
bumppp
Old May 15, 2008 | 08:18 AM
speedypeat's Avatar
Ok, silly question, but was the key turned to the "on" position just before the cranking position? That code appears if you don't....
Old May 15, 2008 | 09:17 AM
yikez's Avatar
the code reader and the dealer MUT couldn't get a reading. Could my ecu be the problem?
Old May 29, 2008 | 01:22 PM
yikez's Avatar
BUMP ..
Anyonee? i searched the forums and searched everywhere online with no luck!
Old May 29, 2008 | 01:34 PM
rcheung's Avatar
Have you checked the condition of the wiring harness that connects to the obd2 port?
Old May 29, 2008 | 06:56 PM
1d10t's Avatar
Is your car modded? Still under warranty? Try a battery reset, sometimes that helps electrical gremlins. Disconnect the battery and put the negative and positive cables together for about a minute. ( battery completely disconnected.) Try again. You can have the dealer figure this out. Will cost you 1 hr of labor time at most.
Old Jun 1, 2008 | 01:12 AM
yikez's Avatar
Originally Posted by EVIL MR
fuse.
we checked the fuses and they are ok :/
