need help bought a autometer gauge
Old May 22, 2008 | 08:15 AM
bbyevo8u's Avatar
i got a nother question here: when i get my steering column pod how do i mount the gauge inside? the gauge comes with like a plastic shell around the side and back with to lock nuts to hold the gauge in place, do i glue that placstic shell to the steering pod or something and then put the gauge and lock nuts on to hold it in place? what does eveyone do to mount the gauge in the pod?
Old May 22, 2008 | 10:46 AM
Evoryder's Avatar
drill 2 holes in the column. Use a sharpie with the bracket mount hte point for the hole. Make sure the size of the hole is smaller than the screws.
My autometer gauge old location:
Old May 22, 2008 | 11:13 AM
bbyevo8u's Avatar
no i ordered a column replacement!
Old May 22, 2008 | 12:15 PM
bbyevo8u's Avatar
where did you splice into for light.....the dimmer??
Old May 22, 2008 | 12:21 PM
Evoryder's Avatar
a fuse that comes on w/ the ignition on. You can do the dimmer.
Old May 22, 2008 | 12:27 PM
Burklow's Avatar
Yeah I used the dimmer. 12V Green and white wire.
Old May 22, 2008 | 05:10 PM
bbyevo8u's Avatar
the gauge wires are white & black so you spliced white to white and green to the black!?
Old May 22, 2008 | 05:55 PM
bbyevo8u's Avatar
can someone tell me how i mount the gauge inside my steering column pod?
