which CAT will work?
Old May 24, 2008 | 09:56 PM
flyingwangwang's Avatar
Anyone know what brand of High flow CAT I can use with my APS exhaust. I've read APS exhaust is a pain in the *** when you're mix and match such as buying a high flow cat. The exhaust comes with a test pipe. Since I'm moving back to Texas in July, I'm require to have a cat when I get my car inspected. I'm just trying to find a alternative instead of paying $350 for a APS High flow cat.
Any suggestion would be great, thanks!
Old May 24, 2008 | 10:07 PM
RPRalliart04's Avatar
I think the Perrin HFC should work. Its also reasonably priced. It fit on my HKS set up perfect. I am pretty sure the flanges should be the same on your exhaust. Good luck though.
Old May 24, 2008 | 11:25 PM
Burklow's Avatar
I've heard good stuff about the Perrin HFC. Any HFC could still trigger a CEL, so a spacer may be required. But with the cat, you should pass visual. Anyone chime in on this?
Old May 25, 2008 | 09:24 PM
I've had my Perrin HFC in for about 1000 miles now and still no CEL. And this is with a 3" HKS downpipe leading up to it, plus the cat-back.
