just installed boost gauge...PROBLEM
Old May 27, 2008 | 05:21 PM
bbyevo8u's Avatar
ok i was maxing out my stock boost gauge that reads in bars! witch maxed out at 1.5 bars i think thats "21 & 3/4 psi" anyways i was maxing out in every gear but first so i really needed to get a boost gauge that reads high and in psi ok so i bought an autometer gauge "read up to 30psi" so i install it now i cant get it to go past 20psi unless im in 6th gears at wot and even then it only read up to 22psi where do you guys think the problem is the line the gauge is this gauge off or is the stock gauge off the gauge came with the plastic boost line i just sliped the stock boost hose over about four inches and put three zip ties on it tight i rechecked everything i just dont know whats wrong can someone please help me out here
Old May 27, 2008 | 05:25 PM
bbyevo8u's Avatar
any suggestions will be very helpful!
Old May 27, 2008 | 05:34 PM
joedr's Avatar
EvoM Moderator
Try to set higher boost on the MBC and see if you are reading accordingly on the gauge. Probably your old gauge was reading off and you are only blowing 20 PSI.
Old May 27, 2008 | 05:46 PM
evo8426's Avatar
try pushing the stock boost hose over the nipple on the autometer gauge. stock gauge doesnt read in bar
Old May 27, 2008 | 06:00 PM
bbyevo8u's Avatar
is it safe to do that "turn up the boost to check"?? also my vacuum at idle it about at 20 is that normal? thanks for trying to help me in this stressful time i no i dont have a boost leak cause i just maxed out the stock gauge "22psi" before i swap out for the aftermarket one now it reading 2psi less
Old May 27, 2008 | 06:08 PM
bbyevo8u's Avatar
the stock gauge does read in bars! and there is no nipple to push the hose over its just a compression locknut with the plastic boost line that comes out and i did slide the boost hose over the plastic line for a good four inches then it just wouldnt slide on anymore so i put 3 zips on it!!
i think i'm going to try out what joedr said turn the boost up to see if the gauge is reading right but can someone tell me if it safe to do that just to check??
thanks
Old May 27, 2008 | 06:11 PM
evoracingstar's Avatar
do a vaccum leak test. just do double check to make sure ur not leaken any air. that could be a problem. make sure u got everthing hooked up right! hope u figure out ur problem.
Old May 27, 2008 | 06:33 PM
1d10t's Avatar
Stock gauge does NOT read in bars. Its in Kg/cm^2. 1.0 Kg/cm^2 = 14.223 psi. So 1.5 Kg/cm^2 is 21.3 psi. As the oem gauges may not really be that accurate, either are the autometer boost gauge. Theyre junk IMO. Had two of them fail on me.
Old May 27, 2008 | 06:40 PM
1d10t's Avatar
The brass couplers ( called ferrels) may be over tightened which will crush and cut the nylon tubing provided with that gauge assy. You can buy new ferrels at advanceauto (Ive done it! lol) A restriction or cut would tamper the gauges reading.
Old May 27, 2008 | 09:15 PM
bbyevo8u's Avatar
thanks guys!....how do i do i vacuum leak test?
Old May 27, 2008 | 09:17 PM
bbyevo8u's Avatar
oh it doesnt read in bars oops sry but i was close
Old May 28, 2008 | 06:02 AM
bbyevo8u's Avatar
what should my vacuum be reading and how do i do a vacuum leak test?
